Yet another 408 build begins - Ford Bronco Forum
 10Likes
post #1 of 104 (permalink) Old 01-30-2013, 05:23 PM Thread Starter
V8Ranger's Avatar
Bronco Info: 1996 5.8 EB, 33's
Started by purchasing a used motor/tranny/xfrcase thru CL. Supposedly from a 96 pickup, it turned out to be a non-roller block w/speed density. Did get a spare E4OD, transfer case is manual shift. Not too bad for $500, lots of spare parts.
IMG_1609 by Carl Campbell, on Flickr
Got a set of GT40 heads from an Explorer and a new set of Pace shorty headers. Pictures of both here http://www.fullsizebronco.com/forum/...d.php?t=217018
Some fun parts showed up yesterday - the 408 stroker kit. Its from AD Performance, Scat crank and rods with Probe pistons.
IMG_1608 by Carl Campbell, on Flickr
IMG_1589 by Carl Campbell, on Flickr
IMG_1590 by Carl Campbell, on Flickr
IMG_1586 by Carl Campbell, on Flickr
IMG_1591 by Carl Campbell, on Flickr
IMG_1584 by Carl Campbell, on Flickr
More to come as things progress...
Carl
The wife left a note on the fridge... "It's not working, I can't take it anymore! Gone to stay with my Mother"
I opened the fridge, the light came on and the beer was cold........
What the hell is she talking about?
V8Ranger is offline
post #2 of 104 (permalink) Old 01-31-2013, 06:32 PM Thread Starter
V8Ranger's Avatar
Started by getting some of the peripheral components cleaned up.
IMG_1631 by Carl Campbell, on Flickr
Carl
V8Ranger is offline
post #3 of 104 (permalink) Old 01-31-2013, 09:21 PM
Please PLEASE do not use the stock 5.8L upper for a 408 build. Buy the GT lower! Better power, more upper intake options too. Remember after the E7 heads the next bottleneck on the 351W is the intake. If you already have GT40 heads, get them ported and polished. No sense in building a beast shortblock to only bottle it up from poor flowing heads and intake.
rebelranger is offline
post #4 of 104 (permalink) Old 01-31-2013, 09:56 PM
MARBLE GARGLER!
351w500's Avatar
I agree totally !
351w500 is offline
post #5 of 104 (permalink) Old 01-31-2013, 09:59 PM
Bronco Logic's Avatar
x3
Check out my Bronco Logic YouTube Channel!
1996 Wht Sport-MAF/OBD II 466, tons,38s
1996 Wht EB-KR'd 351, 4",33s
1976 Ranger-351 EFI,C4,Twin'd D20, 5.5",37s
SOLD 34 others....
Bronco Logic is offline
post #6 of 104 (permalink) Old 02-02-2013, 01:18 PM Thread Starter
V8Ranger's Avatar
A few more goodies have arrived: Oil pump drive and mounting studs, harmonic balancer bolts with square drive and main stud kit. Now I can take the block to the machine shop.
IMG_1662 by Carl Campbell, on Flickr
I understand where you guys are coming from, but I actually want to keep it 'bottled up' a bit at first. The rest of the drive line has 230k miles too, so I want to get it running and see how the tranny does. I fully intend to go bigger heads, intake, etc. at a later date.
I am doing some port work on the GT40 heads and will post pics when they're done.
If the tranny looks like its doing ok after I get it running, my next purchase will be an Edelbrock truck intake.
Carl
V8Ranger is offline
post #7 of 104 (permalink) Old 02-03-2013, 09:21 AM
Get the eddie truck intake now. If you're spending money on ARP bolts, porting, and a stroker kit, put your money where you will feel it the most. You wont regret it but should you, I'll buy it immediately from you.
SOLD 34 others....
post #8 of 104 (permalink) Old 02-03-2013, 01:07 PM Thread Starter
V8Ranger's Avatar
I'm concerned about a snow ball effect - bigger intake, then it will need bigger injectors, then bigger throttle body, then bigger mass air meter...
I need to take this in managable chunks and the bottom end is first as its getting ready spit the rods out now.
I promise I'll buy an intake.
Carl
V8Ranger is offline
post #9 of 104 (permalink) Old 02-03-2013, 04:05 PM
Chillin on the Gulf Coast
cajunrebel's Avatar
Subscribed. I am looking into the Probe Ind. 408W kit as well. my only complaint is that I do not want to bore a block out to 4.030" unless it needs it. If I can get a block that can live with a light honing like my 302 got then I would rather save the cylinder wall thickness for later should I need to rebuild down the line. I also have my eye on a set of roller conversion lifters on Ebay. Guy said he ran them for a while and then went to a solid roller cam. They last pretty well and can be torn down and cleaned if one is ticking (did it on the factory ones in my 302). What is the dish size of your pistons. I have not looked a lot into the compression numbers to calculate my preferred head and piston sizes.
cajunrebel is offline
post #10 of 104 (permalink) Old 02-03-2013, 05:26 PM
Thread Killa
jowens1126's Avatar
awesome build! How much do you anticipate having in the entire build once its in the truck, and tuned?
I think SeattleFSB ended up with about 15k in his.
jowens1126 is offline
post #11 of 104 (permalink) Old 02-03-2013, 05:29 PM
Thread Killa
jowens1126's Avatar
+1 on the snowballing thing though. Bigger engine, more power, kills transmission, fix transmission, breaks driveshaft, fix driveshaft, breaks rear end, fix rear end, Brakes explode. lol its a never ending cycle it seems.
post #12 of 104 (permalink) Old 02-03-2013, 07:37 PM Thread Starter
V8Ranger's Avatar
Pistons are 24cc dish, supposed to 9.5 compression with 64cc heads.
I'm planning on a Howard's retrofit roller kit with link bar hydraulic roller lifters. Actually cheaper than stock replacement roller can and lifters.
I haven't totaled up costs yet, but I'll will...
Carl
V8Ranger is offline
post #13 of 104 (permalink) Old 02-03-2013, 09:23 PM
Thread Killa
jowens1126's Avatar
You wouldnt by chance have a green tailgate on that thing would you? Ive seen 3 blue/tan EB Broncos here in Orlando, including mine, that have a green tailgate.
post #14 of 104 (permalink) Old 02-03-2013, 10:20 PM
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: transforming...
nice, I am going to keep up witht this one
UNION PRIDE
MY STUPIDMOTORS
BRONCONUT is offline
post #15 of 104 (permalink) Old 02-04-2013, 06:28 AM Thread Starter
V8Ranger's Avatar
No, no green tailgate. I wouldn't drive it that far right now, its knocking too bad I stick around Merritt Island / Cocoa.
Carl
V8Ranger is offline
post #16 of 104 (permalink) Old 02-04-2013, 12:44 PM
cajunrebel's Avatar
The retrofit lifters cost a fair bit more than stock lifters from what I have seen. But its about the same as the increase in price for a roller ready block. I also agree with your choice of limiting your top end until you get your drivetrain fixed up to withstand it. If you need any help with this I will be in Florida starting in March and can help with a lot of stuff.
post #17 of 104 (permalink) Old 02-05-2013, 01:35 PM
aka: kemicalburns
TravisITGuy's Avatar
lots of guys in the mustang community have had decent success with the typhoon brand of intakes. they have the equivilant to the edelbrock versions we use and are consderablly cheaper.
i agree though keeping it bottled up for the time being.
TravisITGuy is offline
post #18 of 104 (permalink) Old 02-05-2013, 06:47 PM Thread Starter
V8Ranger's Avatar
Do they have an equivalent to the Edelbrock truck fuel injected intake? I am definitely staying fuel injected with the stock configuration (if not stock components).
Carl
V8Ranger is offline
post #19 of 104 (permalink) Old 02-05-2013, 09:24 PM
Thread Killa
jowens1126's Avatar
I found this article on the Typhoon Intake.
http://www.fordmuscle.com/archives/2003/12/efiintake/
post #20 of 104 (permalink) Old 02-06-2013, 08:02 AM Thread Starter
V8Ranger's Avatar
Looking at Summit, the Typhoon is maybe $100 less than the Edelbrock, but is made for Mustangs so single blade throttle body on the side rather than dual at the front.
Carl
V8Ranger is offline
