96 Build - Page 28 - Ford Bronco Forum
 925Likes
post #541 of 554 (permalink) Old 07-11-2019, 05:34 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Originally Posted by schwim View Post
What should it be set to though? What measurement of distance between the string and the front portion of the wheel? Is that something different for each vehicle or is there a general safe measurement?
I set the toe in for a TTB Bronco at 1/8" . The method I use is similar to this:
MY BUILD THREAD
cobrajoe is online now
post #542 of 554 (permalink) Old 07-11-2019, 08:46 PM
Doosenberry's Avatar
Bronco Info: 78 Bronco 351M/NP435/NP205 - Holley Sniper - Hedman Headers - MT Classic 3's - 35" MT Deegan 38s
I'm assuming this would only work if you had all four wheels with the same width and offset, same size tires, and aired up exactly the same? I only say that because I've seen people use small spacers on front wheels to gain clearance from tire rubbing and whatnot. Also, if you were aiming for 1/8" toe-in would you have the front of the wheels on each side in further than the rear by 1/16" to equal a total of 1/8" or are you aiming for 1/4" total with 1/8" in on each wheel?
I've seen people use a tape measure or a bar/2x4 cut to length and measure the distance between the front of the front wheels and the back of the front wheels and do it that way as well.
cobrajoe and Rusty in Wis like this.
77 F100 Custom SWB - 302/C4 2wd ~ My Daily Driver
78 Bronco Custom T/S - 351M/NP205/NP435 4wd ~ For Fun
75 F150 Custom LWB - 460/C6 2wd ~ Deceased
Doosenberry is online now
post #543 of 554 (permalink) Old 07-11-2019, 09:24 PM
Rusty in Wis's Avatar
I think Joe still owns some plum bobs.
good read
http://www.longacreracing.com/userfi...t/Squaring.pdf
cobrajoe likes this.
Rusty in Wis is offline
post #544 of 554 (permalink) Old 07-11-2019, 11:56 PM
Retired Staff
I've used a 10 ft. fluorescent bulb to align a bike tire. whatever gets 'er done and done true, will do.
reptillikus and CDA 455 like this.
BikerPepe` is online now
post #545 of 554 (permalink) Old 07-12-2019, 06:07 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
@Doosenberry , correct on all counts; I always measure off of the rim, not the tire.
MY BUILD THREAD
post #546 of 554 (permalink) Old 07-12-2019, 10:46 AM
JustRight's Avatar
Bronco Info: 1983 Bronco XLS, manual warn hubs, 4.9, 4-speed manual, 4-bbl, headers, factory air
Great idea! That's thinking outside the box.
BikerPepe` likes this.
JustRight is offline
post #547 of 554 (permalink) Old 07-13-2019, 08:20 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
They do work, I used 8 ft fluorescents and a framing square to do the 4 wheel (IRS) alignment on my Daytona Coupe to get it to handle at speed. I actually took some rough measurements off a Porsche Turbo Carrera in a parking lot, lol. I had several alignments done that just didn't handle right: one day I was behind a Porsche on the highway and saw the negative camber on the rear wheels, so I duplicated it.
Anyways, back at it again today. I machined the spacers down to .50 and installed them. This netted me about 1" and I'm happy with the stance.
After that, I played with the adjustable bushings, taking it for a ride around the block each time I made an adjustment so it would be settled in. Once I was happy with it, I did the toe again.
I took it for a long ride and the steering started feeling a little weird; the springs settled in a bit and my camber and toe changed.
I'll make a adjustment again next week, now that I know the height is where I want it.
Enough work, now it's time for some of that #27 Jack Daniels.
MY BUILD THREAD
post #548 of 554 (permalink) Old 07-14-2019, 08:38 PM
Its All brought on about a string. Learn boys
post #549 of 554 (permalink) Old 07-14-2019, 09:20 PM
MidlifeCrisisUndrWay
CDA 455's Avatar
Bronco Info: '94 XL/6"coils/1tonTRE Flip/Upgraded E4OD(To PSD specs)/2"rr lift blk/5100 Bilsteins/33"BFGs.
good read
So; in a nutshell, the string is to confirm the front tires are facing forward/squared?
Is that correct?
μολὼν λαβέ
CDA 455 is offline
post #550 of 554 (permalink) Old 07-15-2019, 06:13 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
It's to square your front and rear axle/tires; much like you would square up a wall if you were building it on the ground.
Like a square vs parallelogram.
CDA 455 likes this.
MY BUILD THREAD
post #551 of 554 (permalink) Old 07-15-2019, 02:14 PM
CDA 455's Avatar
And you use the adjuster sleeves on the tie rods to correct/adjust toe-in/out?
μολὼν λαβέ
CDA 455 is offline
post #552 of 554 (permalink) Old 07-15-2019, 04:06 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Yes, the sleeves are right and left hand thread, so you can lengthen or shorten the tie rod to bring the front of the wheel in or out to set the toe.
Also, @CDA 455 , I may have answered this wrong now that I re-read it:
In a "nutshell" my answer is still yes. I read the quote answering the question more on the use of the plum bobs, rather than the string. The diagram I had posted represents squaring using the string & plum bob method, but I'm thinking you are asking on the use of the string for setting toe-in.
This diagram shows toe-in using a string, but I exaggerated the toe in. In real life, you would have the string "neutral"; touching the sidewalls of front and back evenly and then adjusting the toe in 1/16"on each side to give you a total of 1/8".
I hope this helps.
SRWillis, CDA 455 and Doosenberry like this.
MY BUILD THREAD
post #553 of 554 (permalink) Old 07-17-2019, 08:04 PM
wasp1971's Avatar
Bronco Info: 95 Eddie Bauer, 5.8
Very impressed with all of your work sir.
BikerPepe` and cobrajoe like this.
Rough Country/ProComp 6" suspension lift, extended radius arms, 33" BFG's, Mile Marker hubs
wasp1971 is offline
post #554 of 554 (permalink) Old 07-18-2019, 06:08 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Thank you @wasp1971 , much appreciated.
MY BUILD THREAD
Tags
ttb
