Electric Fan in 79 Bronco - Page 2 - Ford Bronco Forum
 35Likes
post #21 of 43 (permalink) Old 03-24-2019, 07:31 PM
Resident Nice Guy
schwim's Avatar
Originally Posted by FirstPriority View Post
Plus love the extra engine compartment space to do other work.
I love this as well. It makes working in the bay a lot easier.
79BroncoSpringTx likes this.
schwim is online now
post #22 of 43 (permalink) Old 03-24-2019, 08:32 PM
Redneck Engineer
79BroncoSpringTx's Avatar
Well my fans are fixing to get tested for sure finally. My BKO sat most of last year but she's back on the road here lately. Driving her a bit more slowly. Plans are to keep driving her more. It hit 80 today so summer is right around the corner. I bought an indicator light I plan to install in the cabin so I will know when the fan is running. Also have parts to install manual fan on. My Flexlite does run after engine shutoff. Sorry @schwim to hear yours failed. I do believe this is a better setup than the old manual fan. Schwim you do have a 3G alternator upgrade correct?
allcruisen likes this.
79BroncoSpringTx is offline
post #23 of 43 (permalink) Old 03-24-2019, 09:41 PM
Resident Nice Guy
schwim's Avatar
I do. I initially tried to run the fans with the stock alt and that went comically bad. I'm really looking forward to see how my setup works with each fan on a separate controller. I think it's going to work much better.
allcruisen and CrazyBRONCOguy like this.
post #24 of 43 (permalink) Old 03-25-2019, 03:33 AM
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: '95 302 XLT
Yeah @79BroncoSpringTx the one I have installed on my 95 Bronco also runs for about a minute or two after shutdown... I also have a switch to turn the fan on manually as well as an indicator light inside the cab...
Allcruisen
VOTE For FOTM !!!
"DEATH BEFORE DISHONOR"
allcruisen is online now
post #25 of 43 (permalink) Old 03-25-2019, 09:04 PM
Redneck Engineer
Allcruisen
So hows the light and manual override working? I would think it would be good. i'm actually tempted to install and additional set of gauges that were originally in the bronco. A manual set. Then i could compare them to my Dakota Digital gauges.
post #26 of 43 (permalink) Old 03-25-2019, 09:19 PM
allcruisen's Avatar
I'll get some pictures tomorrow... It works out great... I have dual fans, one for the AC and the cooling fan actually is a two speed fan. The controller works the low speed and auto off and the switch inside the cab runs the high speed...
PS This is on my 95, My sons 79 had a two speed single fan from a Taurus inside the OEM Fan shroud...
Allcruisen
VOTE For FOTM !!!
post #27 of 43 (permalink) Old 03-26-2019, 02:28 PM
OX1
OX1's Avatar
Did someone say redundancy, how about dual "tortus" fans
and soft start controller.
79 XLT, 400/C6/MOG 404's/43 SX STICKIES, 8.5" lift.
OX1 is offline
post #28 of 43 (permalink) Old 03-26-2019, 03:38 PM
allcruisen's Avatar
@OX1 , If those are Taurus fans then that is not what I installed in my son's '79. Might of been out of a Lincoln ???
@79BroncoSpringTx , as mentioned yesterday here are the pictures of my switch and the LED light that lets me know the fan is on {auto} or by me hitting the switch.
Hope this helps,
Allcruisen
VOTE For FOTM !!!
post #29 of 43 (permalink) Old 03-26-2019, 07:53 PM
marshallnoise's Avatar
Bronco Info: '79 Custom
Yep, if it was me, I would be getting a Taurus or Volvo fan. Volvo has a sweet two speed relay setup that comes stock on their vehicles. You snag that relay setup and the fan, all you need is a way to trigger the relays. For that, I would use a BMW e36 318i coolant temp sensor. All you do is wire the power to the battery directly, hit a ground, then use the BMW coolant temp sensor to trigger the hi/lo relay setup.
Here is a great write up! https://www.therangerstation.com/tec...tric_fan.shtml
This way, it runs automatically.
1995 BMW 540i
'79 SHTF Daily Build
1997 Toyota 4Runner (locked) - Sold but close to me
marshallnoise is online now
post #30 of 43 (permalink) Old 04-14-2019, 11:00 AM
newageroman's Avatar
Bronco Info: '78 Bronco XLT - Buck the Truck
Ok, jumping in this thread if you guys don't mind. My 78 has analog temp gauge off the thermostat housing, no fan shroud, old radiator etc and running hot while just moseying around the neighborhood. I am hoping to finish the 3G alt upgrade this afternoon.
I *was leaning toward a dual flexlite fan kit - similar to 79Broc springTX installed in his build - look super clean. But, I still have stock old radiator, AND just spoke to my dad who said he thinks he has a 94 taurus fan laying around the house somewhere = free. I am planning to eventually go Holley sniper and have whatever fans controlled by it, but do like the thought of maunal override and indicator light(s). If I could get the first stage turned on at ~180/185 using lower rad hose sensor and then have a manual switch for high - for now at least , id be good with that.
So pls school me on taurus fans, are they all 2 speed? What years? Should I snag the relays that run the fans on it as well and try to use them? Any threads to point me to. Thx, and sorry to hijack, but seemed related. thx.
Owner of Buck the Truck. My Build Page
newageroman is offline
post #31 of 43 (permalink) Old 04-14-2019, 10:35 PM
trustyrusty's Avatar
before you go reinventing the wheel
make sure the cooling system is up to snuff
if rad is old ,shitty and has poor cooling ability,all the fans in the world wont help it
if rad is old or original and suspect,replace it with a quality one for the application(not a $98 similar supposed to fit unit from ebay)
I prefer copper /brass and I had 4 core made for my 78 and was still working well 25yrs later when I sold truck last year! and never had a cooling issue with that truck ,even with NO cooling fan 5 months of the year ,or when I ran a 16'' universal electric fan up against the rad with no other shroud.
I am not a fan of aluminum rads in our trucks
I hear more people have cooling issues with them than not
trustyrusty is offline
post #32 of 43 (permalink) Old 04-15-2019, 11:14 PM
I flushed out the radiator today. The coolant was almost all nice and green. The fins look good, it doesn't leak, it looks non-original, but in good condition. Ran a water hose in the top and it seemed to flow well, so I think my problem lies elsewhere. I'm going to try one of the Advanced Auto 180 thermostats that was mentioned in another thread tomorrow.
post #33 of 43 (permalink) Old 04-16-2019, 02:54 PM
OX1
OX1's Avatar
I have a Lincoln Mk VIII fan and the shrouding is significantly larger, but the fan is close.
I believe the Mk VIII is a bit more CFM than the Tortus, but dual Tortus is so crazy
(CFM wise) over the top for most people. It works great when you are sitting on an obstacle and
banging against that converter, spewing heat like crazy for many minutes.
OX1 is offline
post #34 of 43 (permalink) Old 04-16-2019, 03:44 PM
allcruisen's Avatar
OK, I are confused. Are both your fans the same? The one on the passenger side looks more of watt I had installed in my son's 79.
Is that one on the passenger side a two speed fan ?
Thanks,
Allcruisen
VOTE For FOTM !!!
post #35 of 43 (permalink) Old 04-16-2019, 07:46 PM
September 15 FOTM
ANGELO's Avatar
Bronco Info: 1978 bronco 351 c6
20181021_135952 by Angelo Mehtala, on Flickr
20181021_151035 by Angelo Mehtala, on Flickr
dual fans from a ford windstar fit these radiators almost perfect. im using a variable speed flex a lite controller for these, and have a manual on and manual off toggle switch to override the automatic controller if needed. keeps my truck cool
1992 f250 turbo intercooled idi ~ D.D./work truck
1978 bronco "grits"~ trail truck
1984 f350 with sleeper "The Rig"
ANGELO is online now
post #36 of 43 (permalink) Old 04-16-2019, 07:47 PM
September 15 FOTM
ANGELO's Avatar
post #37 of 43 (permalink) Old 04-17-2019, 10:25 AM
That looks great! I've read about the dual windstar fans in older threads.
Which flexlite controller did you use, about how much was it? How did you wire manual switch?
post #38 of 43 (permalink) Old 04-17-2019, 10:39 AM
Thatís all I run is electric fans, get stuck in Chicago with stop and go traffic and you will learn real quick why. Fuel economy and HP are my other motives for the as soon as it pulls in the driveway mod. You can also turn the fan on constant for extra cooling while moving slow or running A/C on a hot day, win/win either way for me.
post #39 of 43 (permalink) Old 04-17-2019, 11:01 AM
allcruisen's Avatar
I can't find any pictures but I know that fan that @OX1 has on the passenger side is exactly the same one I put in my son's '79. I did install just the one fan inside the OEM fan shroud and even with the Florida heat an AC, that Bronco never overheated.
@ANGELO I like that setup.
Allcruisen
445 FE Bronco likes this.
VOTE For FOTM !!!
post #40 of 43 (permalink) Old 04-17-2019, 11:40 AM
I have a build thread for installing my fan on my 78, the radiator I had to modify as it was for a 460 equipped E450 Box truck in copper. Canít find my threads anymore but I fabricated everything from aluminum for the shroud. It is important to use a shroud that is spaced away from the core enough to pull air from the full core. I used an 18Ē single and a fan wet sensor on the thermostat housing that is thread in adjustable.
Similar Threads
Recalls? leomags Noobie Bronco Tech Questions. Flame free zone! 2 01-27-2019 03:22 PM
Observations on switch to electric fan Rick3373 Noobie Bronco Tech Questions. Flame free zone! 21 03-21-2004 11:33 AM
