Ford Bronco Forum - View Single Post - DD/Beater Build! (96)
post #19 of (permalink) Old 12-16-2016, 03:39 AM Thread Starter
reptillikus
The caliper brackets are from the same 85 K20 axle. It slips over the spindle, and is retained by the spindle studs. You reuse the spindles, spindle studs, wheel bearings, hub, rotor, caliper, caliper bracket, & stub shaft from the Chevy axle. Basically everything that attaches to the knuckle.
The 'new' knuckles are from a pre-94ish bronco; can't reuse the 96's knuckles cuz they use 5 spindle studs instead of 6 like all other Dana 44 axles. So doubtful I'll be able to retain the 4WABS system.
reptillikus is offline
