Has anyone ever had a hell of a time removing a pitman arm from the steering box? - Page 2 - Ford Bronco Forum
post #21 of 60 (permalink) Old 11-20-2007, 01:06 PM
Felix.'s Avatar
Bronco Info: 1996 Bronco
Found this in another thread:
...sums it up pretty much.
1996_ XLT_ 302cid._ 4AOD_MSD-6A ignition_Warn hubs_Trans. cooler_Rust.
Felix. is offline
post #22 of 60 (permalink) Old 11-20-2007, 05:37 PM
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Fireguy50 is offline
post #23 of 60 (permalink) Old 11-21-2007, 02:00 AM
I broke several cheap pullers. I finaly borrowed a snap-on puller and added some heat and it came right off.
bfree likes this.
redbeast9 is offline
post #24 of 60 (permalink) Old 11-21-2007, 01:51 PM
Bronco-In-Training's Avatar
Bronco Info: 1983 Bronco, 6" Superlift, 351w, C6, NP 208, 38.5" tires, dana 44 with ARB, 5 lug dana 60, 4.88 gear
I had a lot of problems with things not coming lose when putting on my lift, but the pitman arm (thankfully) came off quite easy. Several days of PB Blaster and a cheap puller from AZ.
Bronco-In-Training is offline
post #25 of 60 (permalink) Old 11-21-2007, 02:31 PM
AHorseWithNoName's Avatar
Bronco Info: 2 wheels baby!
I made my own puller after wrecking the cheapo a friend loaned me. He now has a Cracker made custom p/a puller.
AHorseWithNoName is offline
post #26 of 60 (permalink) Old 11-21-2007, 02:46 PM
yup, everytime gotta use snap-on puller & a torch.
fordhorse is offline
post #27 of 60 (permalink) Old 11-21-2007, 03:18 PM
Bronco Info: 1988, 302, c6 auto
Torches are your friend.
ChrisIDV is offline
post #28 of 60 (permalink) Old 11-21-2007, 03:40 PM
has no skidplate
rightofway's Avatar
Bronco Info: 1990 5.8l on 33" BFG A/T, warn hubs
hit it with enough kroil and it'll fall of on it's own
rightofway is offline
post #29 of 60 (permalink) Old 11-21-2007, 05:03 PM
Bronco Info: 1989 XLT 351W (5.8L) C6 BW1356 4" SUSP. LIFT
I was replacing the stock pitman arm with a dropped pitman arm (4" lift). I cut the edge of the pitman arm almost to the shaft and it popped off the shaft easy after that. It hurt when the pitman arm and the puller fell on my ankle though. Damn it hurt.
slaga is offline
post #30 of 60 (permalink) Old 11-21-2007, 05:08 PM
El Bicho's Avatar
Bronco Info: 1988 XLT 5.8, AO Dominator Trans, BW 1345, 3.55 gears, Lots of miles, 31 x 10.5 tires, Stock Wheels
I couldn't get mine off, either. So, I just called Chuck Norris, and he came over and pulled it off with his teeth.
El Bicho is offline
post #31 of 60 (permalink) Old 11-25-2007, 10:35 PM
yeh last weekend did the same thing as u heat , puller removed from the truck , lube and i finally used two caol chisals between the box and the arm . pain in the you know what!
badass bronco is offline
post #32 of 60 (permalink) Old 11-25-2007, 11:02 PM
johnorama's Avatar
Bronco Info: '86, 302, efi, C-6, 4" lift
I had to cut mine.
I tried pullers, hammers, heat, break-free... Only my trusty cutting wheel did the job along with my 25 gallon air compressor running constanly for about an hour.
johnorama is offline
post #33 of 60 (permalink) Old 12-06-2007, 11:40 PM
Pardon my ignorance, but I have to take off the pitman arm on my 95. What is PB Blaster ?
Thanks - MM
mm88gt is offline
post #34 of 60 (permalink) Old 12-06-2007, 11:54 PM
Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
It's a penetrating oil, sold in a can with writing all over it and a yellow top. You can get it at most auto-parts stores.
Kroil is another kind of penetrating oil. Much more expensive, but I think it works better, too.
Sandy
sewiv is offline
post #35 of 60 (permalink) Old 12-07-2007, 12:47 AM
Kitteh Commandaar!
KC200787's Avatar
Bronco Info: 2006 F150 Lariet 4x4 ECSB - 5.4 Trition
I now fear the pitman arm....
My Supermotors PageMy vehicles:
DD - Truck: 2006 Ford F150 Lariet, Ext. Cab, 5.4, Auto, 105K
Truck: 1995 Ford F150, Ext. Cab, 5.0L, 5sp, 189k miles, 4x4, 31" Trailblazer Mud Terrains - currently broken
KC200787 is offline
post #36 of 60 (permalink) Old 12-07-2007, 02:29 PM
And with good reason. It was the worst part about doing the SAS we did on my 1990. I actually ended up breaking my finger when it finally gave loose in one of the several rounds of installing and removing the pitman arm.
It sucks to get off, but there are a few tricks that do work. Soak it in PBlaster for a few days before you're going to remove it. Use a torch to heat it up. A BFH works well too...
hossman777 is offline
post #37 of 60 (permalink) Old 12-07-2007, 02:34 PM
Chrome gets me home
jslax04's Avatar
Bronco Info: 1994 Bronco XLT 351w 6" RC lift, 35" General Red Labels on 17x9 KMC wheels, 4.56 gears LS rear
yeah the pitman arm is a dirty whore...
jslax04 is offline
post #38 of 60 (permalink) Old 12-07-2007, 02:48 PM
Captainp4's Avatar
Bronco Info: 1978 xlt ranger trailer special
puller+impact+sledgehammer and it popped right off.
Paul
78 Bronco, tons, cage, 39.5" boggers, 460, etc.
96 F350 7.3PSD zf5
Captainp4 is offline
post #39 of 60 (permalink) Old 12-07-2007, 03:13 PM
Chrome gets me home
jslax04's Avatar
i used the same technique except we had the puller on there putting pressure on it for about an hour and a half then my roomate hit it with a hammer one last time out of frustration and BANG...popped right off
jslax04 is offline
post #40 of 60 (permalink) Old 04-15-2012, 07:44 PM
What size is the nut that holds the pitman arm onto the gearbox?
GetBent4x4 is offline
You may not post replies
