New Headers - Ford Bronco Forum
post #1 of 17 (permalink) Old 03-03-2010, 03:29 PM Thread Starter
Bronco Info: 351W c-6 9inch 4inch susp 35" ProComp MT HO alt Weiand water pump MSD6T Hedman Hedders
New Headers
They arent quite fitting right. Drivers side slightly touches the front driveshaft and passenger side slightly touches the frame... any suggestions to tweaking them?
sa2ms7on is offline
post #2 of 17 (permalink) Old 03-03-2010, 04:24 PM
Bronco Info: 1995 Ford Bronco XLT 351W
a big crowbar
bds3795 is offline
post #3 of 17 (permalink) Old 03-03-2010, 05:34 PM
aka: kemicalburns
TravisITGuy's Avatar
these must be long tube headers? more info on the product and what they are would help.
TravisITGuy is online now
post #4 of 17 (permalink) Old 03-03-2010, 11:49 PM
Bronco Info: 1987 Bronco XLT 302 C6 Trac Lok Tow and Handling package 33X12.5 TSL Thornbirds grooved
use a ball peen hammer and bet the sh*t out of it till it fits.
ButcherBronco is offline
post #5 of 17 (permalink) Old 03-04-2010, 12:57 AM
Cleaning the trails
Tony R's Avatar
Bronco Info: 96 Forest Service Retired 188K original miles on the odometer and still going strong
What shape are your motor mounts in? Just sounds like your engine is not centered.
If it is, what they said above...
Looking for So Cal West Coast AAT Volunteers
96 Fed Gov't Surplus 5.8L XL 4" BDS Lift
KI6FGI 146.520
Tony R is offline
post #6 of 17 (permalink) Old 03-20-2010, 10:54 PM Thread Starter
brand new motor mounts. they were flowtech long tube headers. I just sent them back and paid an extra 40 for the hedmans and those fit perfect. Lesson learned: flowtechs are shit :)
sa2ms7on is offline
post #7 of 17 (permalink) Old 03-21-2010, 07:02 PM
On my bassani, the passenger side also touched the frame, but I had alot of clearance on the driver sides.
I used a small hammer and pound the runners until I got the fit that I needed.
broncoflorida is offline
post #8 of 17 (permalink) Old 03-21-2010, 08:10 PM
Kenny's 94's Avatar
Bronco Info: 5.0,e40d,9" 4:11,locker AR-23's,BFG 33's,K&N, 5" lift,Bassani headers/Y pipe,BBK 56mm, sliders
My passenger side Bassani header touched the frame when the eng. would torque. I ground off about a 1/4" of the frame for clearance. Kenny
Kenny's 94 is offline
post #9 of 17 (permalink) Old 04-17-2010, 07:05 AM
Ituen's Avatar
Bronco Info: '95 EB 5.0L no lift, 31" ATs
Thumbs up
I almost ordered a pair of Flowtechs. Thanks for posting this thread!
'95 Bronco EB 4x4, 5.0L, rebuilt E4OD, 3.55 gears, 31" BFG ATs, 167K original miles, Rancho shocks
Ituen is offline
post #10 of 17 (permalink) Old 04-18-2010, 12:05 AM
I love my flowtech's.... they are ceramic coated and fit great. I had to do a little massaging with a crowbar on the drivers side, but only because it was closer than I like it. It fit the first time, but I like about a 1/2 in between the tranny pan and header. No big deal at all.
bds3795 is offline
post #11 of 17 (permalink) Old 04-18-2010, 01:35 AM
brd
Bronco Info: 83 FSB/302 33x12.5x15/ AAL and front coils,c-6,np 208. 8.8,Sag pump,3G alt,eletric fan,91 roller fro
So they fit great after a little custom work.
Steve83;Put DOWN the tools & step AWAY from the Bronco...
brd is offline
post #12 of 17 (permalink) Old 04-18-2010, 02:08 AM
MikE2's Avatar
I had the driveshaft problem with Hedman long tubes. I just heated the pipes at the head and bent the colloctor over an inch.
MikE2 is offline
post #13 of 17 (permalink) Old 04-18-2010, 06:55 AM
Ituen's Avatar
It looks like I may have to "massage" which ever set of headers I buy.
Ituen is offline
post #14 of 17 (permalink) Old 04-18-2010, 10:52 AM
Bronco Info: 1985 Bronco 351w stroked to a 434, Lockers front and rear.9inch rear end, built C6 tranny,
F;owtech headers are a really good header, they arent shit. I have a ceramic set on my 1985 bronco and only had to tweak the drivers side, just so it wasnt under my tranny pan. Not to mention they are over 100 bucks cheaper then headman headers for the same flow rate and primary size tubes.
DadOfFive is offline
post #15 of 17 (permalink) Old 04-18-2010, 11:42 AM
Ituen's Avatar
Flowtech and Hedman headers come from the same company.
Ituen is offline
post #16 of 17 (permalink) Old 04-18-2010, 02:07 PM
So when did Holly start selling hedman? Flowtech is made by Holly.
post #17 of 17 (permalink) Old 04-18-2010, 02:53 PM
Ituen's Avatar
Sorry, I mixed up "Hedman" with "Hooker".
Ituen is offline
You may not post replies
