1995 Premium sound amp bypass harness - Ford Bronco Forum
 6Likes
post #1 of 35 (permalink) Old 05-16-2014, 11:42 AM Thread Starter
truebluefordman's Avatar
Bronco Info: '95 Bronco XLT 5.8/E4OD
Hey guys, have a '95 XLT with premium sound. Previous owner installed an aftermarket CD deck in it. Front speakers don't work. I pulled out the radio and made sure all the connections were right, noticed it had the small square plug for premium sound (not my first one of these).
I'm guessing the front two channels in the stock amp burned out.
Looking for a bypass harness for the amp but not having any luck. On my old '96 Eddie bauer I cut and spliced all the wires but would love to find a connector for under $20 and just plug it in and be done.
Who makes what I need?
'77 F-150 2WD RCLB Build in progress
'78 F-150 4x4 SOLD
'94 F-150 Lightning SOLD
'95 Bronco XLT 5.8/E4OD Cheap thrills
'96 Bronco EB 5.0/E4OD SOLD
truebluefordman is offline
post #2 of 35 (permalink) Old 05-16-2014, 12:12 PM
broncomcq's Avatar
Bronco Info: 1996 Eddie Bauer K&N Cold Air Intake, Warn Premium Manual Hubs, BFG All Terrain Radials
Go to Crutchfield.com. They have adapters that might work.
broncomcq
broncomcq is offline
post #3 of 35 (permalink) Old 05-16-2014, 07:36 PM
Bronco Info: 1994 5.8 XLT in need of TLC
Google for Metra 70-5514 it's available from a lot of sources.
rufus is offline
post #4 of 35 (permalink) Old 05-17-2014, 12:32 AM
You're working against reality.
1) Unplug the dash wiring from the amp harness.
2) Plug it into the standard adapter for the non-amplified radio.
post #5 of 35 (permalink) Old 05-19-2014, 01:42 PM Thread Starter
Steve I think I get your meaning but don't think I have the right connector for that. I have an aftermarket stereo with an adapter harness plugged in to the factory plugs.
Are you saying unplug the harness from the stock amp and route it up to the CD player harness and plug it in there? The small plug or big one?
I'm going off memory, I'll have to pull the deck out and have a look again.
'78 F-150 4x4 SOLD
post #6 of 35 (permalink) Old 05-19-2014, 07:16 PM
So you currently have a "CD player-to-factory premium sound wiring" adapter, and you don't want to use the premium sound amp any more.
1a) Unplug the adapter from the factory premium sound connectors (which are on the amp harness).
1b) Unplug the dash harness from the amp harness (NOT the connectors on the actual amp - follow that wiring, and find the 2 long flat right-angle connectors).
2a) Buy a "CD player-to-standard radio wiring" adapter, and splice it to the CD wires.
2b) Plug the dash harness into the adapter.
3) Sell the amp & its wiring.
http://www.supermotors.net/registry/media/169273
post #7 of 35 (permalink) Old 05-19-2014, 07:23 PM
Thread Killa
jowens1126's Avatar
What he is saying is, Unplug the premium amp, remove all the plugs going to it. Hell Take that sucker completely out.
You should be left with 2 factory connectors. C257 and C258 as shown in the diagram below.
Metra makes adaptors for those 2 connectors (70-5514). They come in a kit available at Best Buy. Plug those into C257 and C258 and wire the rest to your new head unit. Your done.
You will only use the 2 long ones. The other 2 are throw aways. If your wiring doesnt come back to the two connectors stated above, then your wiring has been hacked somewhere along the line. Its in there somewhere, you will just have to find where it got cut and put it back together.
CZ Eddie likes this.
jowens1126 is offline
post #8 of 35 (permalink) Old 01-08-2015, 11:06 AM
Bronco Info: 1994 XLT 5.8L, 1993 Eddie Bauer 5.8L
I have a 1994 Bronco with premium sound apparently because i have the 257 or 258 connector as shown in the pic aboove AND the 282 connector that plugs in to the bottom of my amp. I bought a kit and it had a wide connector that plugged into the 257 (or 258), and one for the 282, but that one didn't have the notches for it to slide in to correctly. It is the plug in the top left of the pic of 4 plugs above. it was essentially the same size and shape but wouldn't slide in due to needing the cutouts in the plug to fit the one coming from the amp. Is there another plug i missed on the top of side of the amp and is there a different kit i need to get? thanks.
aw2055989 is offline
post #9 of 35 (permalink) Old 01-08-2015, 05:40 PM
Trust these guys and get the kit if possible. II didn't on my 95 and it resulted in one big night long headache of splicing wires together lol.
pparts02 is offline
post #10 of 35 (permalink) Old 01-11-2015, 11:15 AM
I'm looking at this pic of the amp and it's wiring that Steve83 has posted. The 2 plugs on the bottom of the amp are what run up to the stereo. it looks like there is a harness that plugs into the right side on that pic that must go out to the speakers? I am confused on what plugs coming from the stereo plug in to what using the bypass harness. The harness I bought is just 1 harness with a long flat plug on one end and a square plug on the other. It has eight wires, 2 each of white, green, gray and purple. Do I plug the flat plug into the plug that goes into the bottom left of the amp and the square plug in to the plug on the right of the amp that goes to the speakers? thanks.
post #11 of 35 (permalink) Old 01-11-2015, 06:03 PM
Bronco Info: '96 Black 302 XLT - '94 Green 351 E. B. both E4OD, 3.55 axles, 31 10.50x15 & a 2018 CT6
Here's the EVTM schematic of the OEM premium sound. Maybe it will help.
http://www.supermotors.net/registry/media/1017246_1
How in the world are you going to fix it if you donít know how it worked in the first place?
Mikey350 is online now
post #12 of 35 (permalink) Old 01-11-2015, 06:18 PM
Originally Posted by aw2055989 View Post
I'm looking at this pic... I am confused... Do I plug the flat plug into the plug that goes into the bottom left of the amp and the square plug in to the plug on the right of the amp that goes to the speakers?
This would be a LOT easier for all of us if you'd upload pics of what you're working with, AND specify what the truck had before you started, and what you want it to end up with.
You need to identify which connectors the truck has, and what you've bought to modify the truck. On the dash wiring harness, there are always only 2 radio connectors: 1 for power, and 1 for speakers (for all radios with speaker-level output). If the truck has factory premium sound, there will be an intermediate (amplifier) harness with 6 connectors: 2 to fit the dash connectors; 2 for the amp; & 2 for the premium (line-level output) radio. An aftermarket kit might have 3 connectors: 2 for the dash connectors & 1 for the premium radio line-level connector.
post #13 of 35 (permalink) Old 01-11-2015, 07:10 PM
1994 Bronco, has premium sound. I am replacing an aftermarket CD player with another one. I am using the same aftermarket harness adapter for the new one that I had for the old one. It has 2 connectors on it, one square for the speakers, and one longer flat one for the power. I plugged in the new unit and it powers up fine, but no sound. After reading many posts about this, I assumed the amp was out. I bought an amp bypass harness that has 8 wires with 2 different connectors on each end, one square and one longer flat one. I assumed I could unplug the 2 matching connecters where they plug into the amp and plug in my bypass harness to them and be done but that won't work as the square plug on the bypass harness doesn't fit the square plug that I took out of the amp. My amp and wiring looks 100% like the picture in the link in the above post. At this point I have completely removed the amp. I am confused because it looks like the square and longer flat connector coming from the dash plugs into the amp, but nothing comes out of the amp. there is a connector that is mounted on the side of the amp but nothing plugs into it, it is capped off, just like in the picture I previously mentioned. I can take pics if necessary tomorrow. thanks for all the help.
post #14 of 35 (permalink) Old 01-12-2015, 08:29 PM
Well I want to upload pics but it won't let me upload attachments. For some reason my posting rules are I can't upload attachments or I can't post new threads. I sent a PM to the person that sent me a welcome message when I joined but I never got a response as to why I can't post except for replies. Sorry, if I can get that fixed I have pics of all the connectors I'm dealing with.
post #15 of 35 (permalink) Old 01-12-2015, 09:32 PM
pfun41's Avatar
Upload them to a picture hosting site like supermotors or photobucket. Then link them here.
pfun41 is offline
post #16 of 35 (permalink) Old 01-13-2015, 12:59 AM
Well I want to upload pics...
http://www.supermotors.net/forums/th...-and-or-videos
post #17 of 35 (permalink) Old 01-14-2015, 12:57 PM
I believe i can simplify this. After removing the amp, i have the 257 plug for power at the dash, correct? My confusion is, where is the 258 plug that i plug the speaker adapter into? the only speaker connection i see is the one for premium sound and that went to the now removed amp. I have an unused plug hanging off the side of the amp, is that it? thanks.
post #18 of 35 (permalink) Old 01-14-2015, 08:35 PM
C258M is part of the dash (main) harness assembly. C258F is only on the mating end of the premium sound (amp) harness. For non-premium trucks, C258M plugs directly into the non-premium radio. Look near the center of this pic, below the red connector:
http://www.supermotors.net/registry/media/907910
There is no "unused" connector on the amp harness - there are 6 as I said before. But if you REMOVED the amp, then you MUST also remove the amp harness. The harness only works with the factory amp.
post #19 of 35 (permalink) Old 01-15-2015, 11:48 AM
Almost glad I just cut the plug ins out and spliced mine together. it was a pain at first but once you figured out the amp situation it went in quickly.
pparts02 is offline
post #20 of 35 (permalink) Old 01-15-2015, 05:28 PM
That was pointless. Unplugging the amp harness would have been quicker & easier, and you wouldn't have ruined a part that's not available new.
You may not post replies
