True Trac vs Detroit Locker opinions - Page 2 - Ford Bronco Forum
 18Likes
post #21 of 55 (permalink) Old 03-15-2016, 01:03 AM
CJREX's Avatar
Bronco Info: 1990, 351W, E4OD, 4" lift, 12k winch, 35x12.50s, 4.56 gears, Detroit rear, Truetrac front
The 33" max is no longer applicable.
I emailed Eaton about this for the 35's on my Bronco and they said it would be fine.
I bought a Jeep, lesson learned...
CJREX is offline
post #22 of 55 (permalink) Old 03-15-2016, 06:28 AM
Cool, I wonder if it would hold up to my truck with the new updates, BB, 35s, stick and all. I would rather have a LSD up front but I an afraid I would break it.
post #23 of 55 (permalink) Old 03-15-2016, 09:48 AM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
Not unless you are trying to do 4wd burn outs on asphalt.
Hillbilly Heaven is offline
post #24 of 55 (permalink) Old 03-15-2016, 11:42 AM
Yup I am, childish yes but what else do you do with a big block and a stick LOL. I definetly plan on going to the strip with it and see what it'll do, maybe high 9s.
post #25 of 55 (permalink) Old 03-15-2016, 02:37 PM
Better plan on Detroit's at both ends at least. Better hope that front Detroit doesn't lock or you will not be able to steer. Or just stay in 2wd if that what you want to do. With a trutrac in the front using it like you are wishing to will end up with you chasing it back and forth across the track. End up slapping both walls.
Only truly safe way to do what you want is with an open diff in the front.
cobrajoe likes this.
post #26 of 55 (permalink) Old 03-15-2016, 03:49 PM
Man of endless projects
Kingfish999's Avatar
i been trying to read their literature for the truetrac. i cant find anything saying what its rated for other than its suppose to be the strongest part of the axle. not sure if that means it would survive in a highly modified axle like a 9" or if it mean stronger than anything in a stock axle with it
i really wish i could do Truetrac in my semi-floating 10.25"
Kingfish999 is offline
post #27 of 55 (permalink) Old 03-16-2016, 10:27 AM
PWMTN's Avatar
Bronco Info: Stretched 96 5.8 with many desert mods.
Did you try to buy? They list them for 12.25 & 10.5
PWMTN is offline
post #28 of 55 (permalink) Old 03-16-2016, 11:55 AM
Here is one!
http://completeoffroad.com/i-123267-...ine-axles.html
post #29 of 55 (permalink) Old 03-16-2016, 12:11 PM
JT1911's Avatar
Bronco Info: 1995 Eddie Bauer Edition, 5.8L, Manual Hubs
I'll plug for the detroit locker!
JT1911 is offline
post #30 of 55 (permalink) Old 03-16-2016, 07:11 PM
they dont work for semi-floating because of the c-clips. full floating only. i emailed them and they said no. no companies make anything that works for semi floating 10.25". and theres no c-clip eliminators for the 10.25 either
post #31 of 55 (permalink) Old 03-17-2016, 09:53 AM
PWMTN's Avatar
I guess you talked to the wrong guy?
My first axle was a 10.25 with c-clip eliminator kit and ended up as a semi float. It was a good setup , but I came on a bargain racing 9" and did the swap. Last I heard the guy who bought my 10.25 is still beating on it after 10 years. I installed an ARB in that axle and do not know if a Trutrac will work?
Did you know that Ford used a semi float as OEM on some trucks?
Keep looking to find the parts you need. And for sure talk to the shops that are building off road axles in order to get real world info.
PaulW
PWMTN is offline
post #32 of 55 (permalink) Old 03-17-2016, 10:56 AM
The Anti Yam!
Gacknar's Avatar
Originally Posted by jfourdyce View Post
Not sure why the original grenaded.
Metal Fatigue
8.8 Trac-Lok carriers are notoriously week due to all the material removed for the ears of the driven discs.
The Greatest Thread on FSB
Gacknar is offline
post #33 of 55 (permalink) Old 03-17-2016, 11:07 AM
PaulW
i have emailed every company that makes limited slip for ther 10.25" and all say the same thing. they do not make anything for c-clip 10.25" since there is no way to put the c-clips in
i have emailed Moser and Strange and they will not make a c-clip eliminator for it. who made the eliminator kit for yours?
i know some 10.25 came factory c-clip. but there very rare cause only some light duty f-250 used them. my 90 F250 has a c-clip 10.25 and the axle and i used a c-clip axle from a 97 F250 for my 5-lug conversion.
post #34 of 55 (permalink) Old 03-17-2016, 11:21 AM
Charlie don't surf!!
I have the Detroit in the rear axle and the TrueTrac in the front axle of my Bronco and I really like them both.
If primarily used on the road with occasional off road, TrueTrac all the way.
That said, my Detroit is not all that objectionable on the street once you are familiar with its manners.
x2 I couldn't have summed it up better myself.
jermil01 is offline
post #35 of 55 (permalink) Old 03-17-2016, 12:09 PM
I love my Detroit lockers, even before they came out with the new Soft Lock version.
post #36 of 55 (permalink) Old 03-17-2016, 12:11 PM
Molar65's Avatar
Bronco Info: 1994 EB 351W
I have a Trutrac in my '03 Lightning. Been in there for about a 100k miles and still works great. And yeah, it gets beat on too.
Molar65 is offline
post #37 of 55 (permalink) Old 04-01-2019, 09:25 PM
Bronco Info: 1994 Bronco XLT 5.8L E40D
Sorry for the old bump but this is a subject I'm researching and I need more info.
I'm planning for a '96 build.
It'll be 80% street.
15% off road.
And 5% street/strip fun, scaring Mustangs.
The TrueLoc looks like the way for me to go, for the stock rear.
But the front is where I'm having trouble, since I'm new to 4x4.
Are you suggesting that a TrueLoc in the front could potentially cause me issues if I'm on the street, pedal to the metal, and maybe even getting into the twisty roads a little bit?
Why would it cause any issues if I don't have 4WD high or low engaged?
I'm honestly a clueless newbie on this subject, so please don't flame me.
Talk to me like a child. That will work better.
CZ Eddie is offline
post #38 of 55 (permalink) Old 04-01-2019, 09:59 PM
NickOille's Avatar
Bronco Info: 1984 Bronco, 351w, C6, custom np208 based doubler, np208, TTB D44, 9", 5.13's
Unless you are hardcore rock crawling, go with the trutrac. It shouldn’t give you any quirks on the street
CZ Eddie likes this.
NickOille is offline
post #39 of 55 (permalink) Old 04-01-2019, 10:07 PM
Blue1551's Avatar
Bronco Info: 92 Bronco on 35Ē tires with solid axel swap with a Duff parts.
If you have manually locking hubs what you have up front is irrelevant until the hubs are locked. If you are running it on a drag track with the hubs locked you are going straight your steering will be minimally affected. A LS is more forgiving than a Detroit. If you are only off roading 15% of the time which one is cheaper.
Train today for tomorrow's unknown!
Blue1551 is offline
post #40 of 55 (permalink) Old 04-02-2019, 11:47 AM
LVSteve's Avatar
Bronco Info: 95 XLT Sport 96 427w/e4od obd II Long tube's Solo stage 4 with Kings 35's & 4.88 Turetracs. RWHP/TQ
Trutrac's Front and back. They take a beating
LVSteve is offline
You may not post replies
