Replace stock dashboard in 92-96 for Fiberwerx fiberglass - Ford Bronco Forum
 12Likes
  • 2 Post By jowens1126
  • 1 Post By milan65
  • 6 Post By milan65
  • 1 Post By dash_cam
  • 1 Post By milan65
post #1 of 20 (permalink) Old 03-15-2018, 06:08 PM Thread Starter
milan65's Avatar
Bronco Info: 1995 4BTA, GM-NV4500, NP205, 37" Toyo, K&N, 3G, Sag, AOB, Deaver, SAS, 8 lugs, ARB, Fiberwerx
Wondering is anybody here has done replacing the original stock dashboard in 92-96 FBS for the one that Fiberwerx makes? Would be great to learn what's involved with the swap - all the wiring, gauges, vents, attachment options etc... If you have it done - got some pictures of the process?
#1 picture is the dash they make. The inspiration came after seeing this fine BKO that was at some point in past for sale. (picture #2). The dashboard is the same, just covered with leather. Thank you Milan
milan65 is offline
post #2 of 20 (permalink) Old 03-16-2018, 08:57 AM
Bronco Info: 1993 Bronco XLT / 5.8L / Auto / MAF Conversion / Hydroboost / D60/Sterling 10.25 conversion
I'm on their site and it's saying "no products found" and I looked under 92-96 Bronco and F-150.
MarktheShark is online now
post #3 of 20 (permalink) Old 03-16-2018, 09:29 AM
Resident Nice Guy
schwim's Avatar
This is the dash in question. No mention of model application on it.
schwim is offline
post #4 of 20 (permalink) Old 03-16-2018, 01:18 PM
fodder's Avatar
Bronco Info: '92 Custom
That sounds about right. It looks like an extremely generic fit that probably requires a lot of trimming and fabbing up mounting points, vent tie-ins, etc. Looks kinda cool when finished, though. I wouldn't have guessed that's a Bronco interior, other than the glimpse of a door panel.
'92 Bronco Build Thread - '95 MAF 5.0, H5 axle code, York OBA.
fodder is offline
post #5 of 20 (permalink) Old 03-16-2018, 07:08 PM Thread Starter
milan65's Avatar
They used to market that dashboard under F150/Bronco and recently changed that to generic one. Not sure why, but it is essentially the same product they have been making for years now. Have you guys looked at the 2nd picture on the initial treat starting step? There you can get a glimpse of how much better it looks in Bronco not mentioning that is does not crack, squeak and probably weight a lot less then stock one. Even without having it covered by leather or similar material it still looks much better/cleaner than the stock one. This dashboard is NOT bolt on by any means and thereís a lot of additional steps that would need to be done to make it work. That is the primary reason why I asked if anybody here had done it, to see what is involved besides the obvious. Milan
milan65 is offline
post #6 of 20 (permalink) Old 03-16-2018, 08:33 PM
Thread Killa
jowens1126's Avatar
BigBlue 94 and milan65 like this.
jowens1126 is offline
post #7 of 20 (permalink) Old 03-16-2018, 09:09 PM
slawson2000's Avatar
Bronco Info: '87 Bronco/'96 front clip & '94 Centurion C350
Putting one of these in is quite a bit of work and coin. I still look and dream, and FWIW I like the McNeil Racing OEM dash.
I know you need to fab up supports for the dash itself. Most OEM stuff is not made to mount to a flush panel (dash). IMHO, gauges and wiring is the easier part. AC/Heater controls, defrost, vents, glove box can be difficult. Most run after market AC if at all.
You may want to snoop around gofastbroncos or race-desert. The guys over there seem to do it a lot more.
If you dive in, take lots if pics. Some of us may follow...
You can't fix stupid...
slawson2000 is offline
post #8 of 20 (permalink) Old 03-17-2018, 04:49 PM
Yo,
Dash/Instrument Panel Carbon Fiber, Fiberwerx Carbon Fiber Dash pic
Source: by unknown via yogib
sweet bronco build pics! - Ford Bronco Forum
Please VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
post #9 of 20 (permalink) Old 03-19-2018, 12:35 PM
Bronco Info: 1989 Bronco XLT 351w
Wow, big job.
TADave is offline
post #10 of 20 (permalink) Old 03-20-2018, 01:11 AM Thread Starter
milan65's Avatar
Miesk5 - Yep - same concept. Slightly different dash but made by Fiberwerx as well. It would be great to learn details of that dash mount.
slawson2000 - McNeil racing owner is father of Fiberwerx owner. I'll try to get some intel from GoFastBronco. Majority of their trucks are bare bone = no A/C and all other DD "things" that clutter the dashboard and make the install more complicated. But won't hurt to ask around.
As of now it seems like nobody here had done it yet. Hmmm. Milan
milan65 is offline
post #11 of 20 (permalink) Old 03-21-2018, 07:33 AM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
I thought the owner of McNeil past away last year, but the family is continuing the company.
post #12 of 20 (permalink) Old 04-08-2019, 01:32 PM Thread Starter
milan65's Avatar
And so it begun. Old dash is out...
dash_cam likes this.
milan65 is offline
post #13 of 20 (permalink) Old 04-08-2019, 01:33 PM Thread Starter
milan65's Avatar
And this goes in... Yep Fiberwerx fiberglass dash and central console, it's just waiting to be delivered now. It's going to be fun project.
milan65 is offline
post #14 of 20 (permalink) Old 04-09-2019, 01:09 PM
Bronco Info: 5th Gen Bronco + Coyote Swap in early planning stages
Wow. So are you retaining your ac/heater and ventilation system?
CZ Eddie is offline
post #15 of 20 (permalink) Old 04-09-2019, 01:42 PM
Retired Staff
BikerPepe` is offline
post #16 of 20 (permalink) Old 04-10-2019, 09:12 AM
Scoop's Avatar
Scoop is offline
post #17 of 20 (permalink) Old 04-10-2019, 10:17 AM
MidlifeCrisisUndrWay
CDA 455's Avatar
Bronco Info: '94 Bronco, 2"front spacer/1ton TRE Flip UpgradeRebuilt E4OD (To PSD specs)/2" rr lift blk/33" BFGs.
oh yea man. gotta see how this goes.
X2!
μολὼν λαβέ
CDA 455 is offline
post #18 of 20 (permalink) Old 04-10-2019, 12:20 PM
dash_cam's Avatar
i do not have the stomach to attempt anything remotely that involved.
BikerPepe` likes this.
dash_cam is offline
post #19 of 20 (permalink) Old 04-10-2019, 01:08 PM Thread Starter
milan65's Avatar
Yes the A/C and all that stays. The old gauge cluster will not make it back. For new gauges, there will be a new set from Autometer and that included tachometer with their sensor that gets attached to alternator. For warning lights - there's going to be some sort of multi quick disconnect connector. The signal from rear axle directly into their speedometer should work. There will be many ARB type switches, cup holders etc. installed. The plan is to use 4 video cameras on the truck - 1 to see trailer hitch, 1 up above spare tire to see what's happening behind truck and 1 underneath the truck and 1 somewhere on the bumper to see immediately in front of it. That will require 2 small size LCD screens that will be installed somewhere in the upper middle section of the dash. Also 12" woofer + amp should fit in there somewhere. But will see about that. Not sure at this point if just painting the dash will be enough or if it would be better to wrap it in fake leather with some backings. It won't be done in one weekend that's for sure. Milan
milan65 is offline
post #20 of 20 (permalink) Old 04-10-2019, 08:03 PM
Not for me, but I am very interested in seeing your results. If you can pull it off, whether "it looks better than factory or not" will still be subjective, but no one will be able to deny all the cool added features and upgrades.
Good luck and do keep us posted on the results.
tim
TS 90F150 is offline
You may not post replies
