Front Coil Springs - Page 2 - Ford Bronco Forum
 10Likes
post #21 of 24 (permalink) Old 04-07-2019, 03:00 PM
Hmm, softride skyjackers would be my pick or Devors. Yeah there expensive but compression and rebound would be smoother.
445 FE Bronco is online now
post #22 of 24 (permalink) Old 04-08-2019, 07:00 PM
LukeNukem's Avatar
Bronco Info: 94 XLT 5.8 -alum heads, dual plane/holley 650,headers, HEI ign -M5OD-
[QUOTE=92BroncoXLT;7192350] Here is what I went through getting it right.
https://www.fullsizebronco.com/forum...-lift-tip.html
94 5.8 - pro comp heads - holley 650 - stainless headers - HEI ign -NO COMPUTERS!! . M5OD-R2, 1345, 3:55, 33"
LukeNukem is offline
post #23 of 24 (permalink) Old 04-08-2019, 07:10 PM
LukeNukem's Avatar
Here is a link to the moog catalog. https://www.motor-talk.de/forum/akti...hmentId=740605 start on page 12 and look at the cc820. Thats your stock spring. Start comparing. notice all the parameters first, especially the end type. I believe that all the aftermarket springs are just the appropriate Moog spring with paint and a new label ..plus a hella markup in price.
JScatt likes this.
post #24 of 24 (permalink) Old 04-08-2019, 11:38 PM
Not exactly, Moog has some taller springs but generally stop around 2.5 if you use a spring for another application like a 78 spring is longer with the same rate or a 460 spring is longer to adjust in ride height. If you went through the catalog you could match coil ID, intended free length and rate and find something close.
JScatt likes this.
Similar Threads
Changing front springs - how to? TexasA&M Noobie Bronco Tech Questions. Flame free zone! 35 01-27-2019 08:43 PM
Different coil springs in the bronco Czerbel Noobie Bronco Tech Questions. Flame free zone! 5 11-26-2018 07:26 AM
O2 sensor bank 2 error Tacotuesday Noobie Bronco Tech Questions. Flame free zone! 17 10-17-2018 08:11 PM
how doees this 4x4 system work? troubleshooting layz72 Noobie Bronco Tech Questions. Flame free zone! 4 07-27-2018 12:23 PM
You may not post replies
