Electrical Issue - Ford Bronco Forum
  • 1 Post By miesk5
post #1 of 4 (permalink) Old 04-02-2019, 07:48 PM Thread Starter
biggum's Avatar
Electrical Issue
Just picked up a buzz in my subwoofer that increases and decreases in pitch with RPM.
If I turn my fan on the tach will increase and jump around.
If I keep the window switch engaged after my windows up or down after they are open or closed my dash lights dim and even go out. Amp meter twitches to the left as well.
Any increase in load makes my tach go up.
Running the heater fan for a bit makes all of this worse.
Weird. Time to check my bat and alt. of maybe leaves on my heater switch in the box.
When you have to shoot, shoot - don't talk.
biggum is offline
post #2 of 4 (permalink) Old 04-02-2019, 08:48 PM Thread Starter
biggum's Avatar
Battery is dead as a door nail. Guess I need to replace the electrical system
biggum is offline
post #3 of 4 (permalink) Old 04-04-2019, 03:53 PM
northern1's Avatar
Bronco Info: 1990 5.8 e4od
the buzzing in your stereo is a bad ground start there
northern1 is offline
post #4 of 4 (permalink) Old 04-04-2019, 05:01 PM
Yo Big,
As Northern advised.
Any other items inoperative?
Or a bad speaker(s). See https://itstillworks.com/fix-buzzing...r-7840996.html
Following by Ford;
" The most effective method of evaluating ignition noise is to compare the radio performance with the engine on, versus engine off. If ignition noise is present with engine running:
Check to see that the spark plug wires are the suppressor type and that the spark plugs are the correct resistor type.
If so equipped, check distributor cap and rotor electrodes for silicone grease, as this may cause ignition noise on FM. This noise is characterized by a "motor boat" type sound on weak to moderate strength stations. The noise can only be eliminated by replacing the distributor cap and distributor rotor (12200) with a cap and rotor that do not have grease.
Missing or Poor Grounds
Check bond strap grounding effectiveness by wedging a large file between metal parts to ensure proper ground, such as between the tail pipe and body, or between the fender and frame, while the radio chassis is playing and the engine is running. Listen for a decrease in the objectionable radio noise. If a reduction in radio noise is noted, first try tightening body and exhaust system clamps and brackets. Then, if necessary, install a new bond strap between the two metal parts to ensure proper ground.
4Missing or Damaged Noise Suppression Components
Noise suppression components may be malfunctioning or missing. Service or replace any missing or damaged components.
Sound Distortion, Premium Sound
Sound distortion can be attributed to any of three components: the radio amplifier (18B849), the radio chassis, or the radio amplifier wiring (19B113) that connects the radio amplifier to the radio chassis. If any of these components is damaged, sound quality will be distorted. The speakers will also cause distortion if any of them are grounded,"
Attached is your 86 wiring diagram
BroncoJoe19 likes this.
Similar Threads
Weird Electrical Beep/Noise.. Ground, Overload? StevenP Noobie Bronco Tech Questions. Flame free zone! 5 03-16-2019 01:20 PM
Electrical issue NewToFords91 Noobie Bronco Tech Questions. Flame free zone! 4 01-24-2019 03:00 PM
Lil' lady bought a '15 F150 w/the 2.7... thoughts? BikerPepe` General Discussion/ Bronco and Wheeling related. 81 11-25-2018 11:56 PM
Steering Column Electrical Issue BigEs89-351 Noobie Bronco Tech Questions. Flame free zone! 1 07-15-2018 02:15 PM
Electrical issue. Please read. 4eyed86 Noobie Bronco Tech Questions. Flame free zone! 15 01-02-2010 04:03 PM
You may not post replies
