Front Wheel Questions - Page 2 - Ford Bronco Forum
 7Likes
post #21 of 24 (permalink) Old 04-09-2019, 10:40 AM
Originally Posted by NickOille View Post
Looks like you have the "ratchet" style spindle nuts. It takes the opposite style of socket than the one you have to get those off. The one with the 4 "tits" sticking out, no ring around them
Yep^^^
Those nuts make a ratcheting noise going on and off. You have to push in to get them to engage and inspect them when out to make sure they are spring loaded.
The bearing preload tightening is a little different than noted above.
Torque to 70 ft lbs while rotating wheel to seat bearing, back it off 90 degrees then torque to 20 ft lbs.
Remember 70/90/20
You can swap these type of bearing nuts for the three piece variety too if the originals become problematic.
Native_Viking is offline
post #22 of 24 (permalink) Old 04-09-2019, 12:22 PM Thread Starter
Bronco Info: 1985 5.8, c6, 4 inch body lift, lots and lots of miles
Thanks for the help guys, I get one of the titty sockets. This bronco is definitely a mashup of an '85 and '86 as I've encountered things like this before.
[email protected] is offline
post #23 of 24 (permalink) Old 04-12-2019, 09:26 PM Thread Starter
Ok, got everything apart and the bearing out (finally after being sick all week), and the bearing looks brand new. The shaft (attached pic) wobbles freely in every direction-- is this normal? Do I just need to repack the grease and torque everything to spec or is there a deeper issue?
post #24 of 24 (permalink) Old 04-12-2019, 09:35 PM Thread Starter
To clarify, only the splined part wobbles, not the tube. It looks like the splined part is connected to a U joint, so wobble should be normal, but if it is not safe or normal I want to know before I put it all back together.
Similar Threads
wierd sounds steve65 2020+ Bronco Tech 1 03-20-2019 01:14 PM
O2 sensor bank 2 error Tacotuesday Noobie Bronco Tech Questions. Flame free zone! 17 10-17-2018 08:11 PM
how doees this 4x4 system work? troubleshooting layz72 Noobie Bronco Tech Questions. Flame free zone! 4 07-27-2018 12:23 PM
You may not post replies
