Fluid type for Sag pump swap. - Ford Bronco Forum
 7Likes
  • 1 Post By Wrencher61
  • 1 Post By AUBronco
  • 1 Post By BigBlue 94
  • 1 Post By fordbronco1995
  • 1 Post By klh95bronco
  • 2 Post By 92BroncoXLT
post #1 of 9 (permalink) Old 04-08-2019, 10:24 PM Thread Starter
silent one's Avatar
What power steering fluid do you guys run with the Sag pump swap, aft or power steering fluid. I search and couldn’t find mention of it. If atf,can I use anything,I have a ton of atf+4 at work.
KEEP CALM AND BRONCO ON
Silent One's Supermotors Page
January 2010 FOTM Winner
@silentjde on instagram
silent one is online now
post #2 of 9 (permalink) Old 04-08-2019, 11:03 PM
Wrencher61's Avatar
They disagree a lot, I’ve read tons, but seems sensible to me to use Dex. 3. Plain old trans fluid. You could use generic hydraulic fluid. That pump would be okay with that, but Dex2 or 3 is probably better. You aren’t going to hurt your pump unless you put water or something in it.....very good pump, Ford should be ashamed of their crappy pump. Ten years or more of the whining shit!!
bsd4083 likes this.
I have been known to sometimes sing “The Hero of Canton” song from the tv show ‘Firefly’ while making breakfast on a weekend morning....
Wrencher61 is online now
post #3 of 9 (permalink) Old 04-11-2019, 09:20 AM
AUBronco's Avatar
I just replaced mine about 2 months ago. Found a lot of back and forth about what to put in there. Finally found several people who agree Valvoline Syn Power worked great and so that's what I put in mine and it has been working good. '
bsd4083 likes this.
Patrick
My supermotors page
AUBronco is offline
post #4 of 9 (permalink) Old 04-11-2019, 10:26 AM
Wild Cayuse
Any hydraulic fluid will work. ATF is what I use, but PS fluid, brake fluid, hydraulic oil, etc will work.
fordbronco1995 likes this.
July, and September!
FOTM forum section
BigBlue 94 is offline
post #5 of 9 (permalink) Old 04-11-2019, 01:00 PM
fordbronco1995's Avatar
Bronco Info: 95 Ox White/Blue Int 5.8L 2” Level 33" Ridge Grapplers 17x9 M/T Classic IIIs Punisher Valve Body
Plain ole mercon fluid
Mercon or Mercon V will work fine
bsd4083 likes this.
EVERYTHING MANUAL EXCEPT THE TRANSMISSION:
fordbronco1995 is online now
post #6 of 9 (permalink) Old 04-11-2019, 01:08 PM
klh95bronco's Avatar
When I researched the threads while doing my swap I found some of the guys were using type F transmission fluid. I started using that and have not had a problem.
I believe by all of the posts above, the statement that "just about anything that is not water will work" is probably true.
I'm sure some may do better than others, but so far, so good with the type F here....
I6-Kid likes this.
Kenneth
klh95bronco is offline
post #7 of 9 (permalink) Old 04-11-2019, 01:18 PM
Foolsize Member
92BroncoXLT's Avatar
I went with type F and haven't looked back.
bsd4083 and I6-Kid like this.
Dylan
1992 XLT 300/M5OD
1978 Custom 351M/C6
2014 Mustang GT
1991 BMW 525i
Ford Parts manager, members needing help researching or locating Ford OEM parts send me a PM!
92BroncoXLT is offline
post #8 of 9 (permalink) Old 04-11-2019, 01:49 PM
Wild Cayuse
"Technically" water could work, but it'll rust things and has a poor hydraulic quality and low boiling point. But dont use water...
FOTM forum section
post #9 of 9 (permalink) Old 04-11-2019, 06:41 PM
Man of endless projects
Kingfish999's Avatar
Ford manuals "E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F"
basicly Fords Power Steering Fluid or Type F. i use Type F
think Mercon is thinner than Type F and can make it abit noisier plus it had more unneeded additives. but newer Ford pumps call for Mercon
Kingfish999 is online now
Similar Threads
1992 4x4 Ford Bronco Eddie Bauer 5.0 cbain1205 Noobie Bronco Tech Questions. Flame free zone! 61 02-16-2019 01:25 PM
95 bronco 5.8l in need of help Ralphv1209 Noobie Bronco Tech Questions. Flame free zone! 11 08-29-2018 03:27 PM
sag pump + 4-bolt / 1-ton steering gear dash_cam Technical Write Ups 19 03-09-2017 03:31 PM
93 bronco, 5.8 liter, stalls out. HELP!!!!!! madscience Noobie Bronco Tech Questions. Flame free zone! 17 07-02-2011 09:12 AM
Saginaw swap: Type of fluid? J A F O Noobie Bronco Tech Questions. Flame free zone! 6 10-16-2003 04:45 AM
You may not post replies
