Interior door handle - Ford Bronco Forum
 6Likes
  • 1 Post By Ranger0297
  • 1 Post By fordbronco1995
  • 1 Post By CrazyBRONCOguy
  • 1 Post By miesk5
  • 1 Post By anaconda
  • 1 Post By BigBlue 94
post #1 of 11 (permalink) Old 04-14-2019, 08:51 PM Thread Starter
anaconda's Avatar
Bronco Info: 1996 Bronco XLT 351w
Went to get out of my truck today and the handle broke. I see a metal and a plastic one listed. Can I swap to the metal style if I currently have the plastic ones? Thanks
anaconda is offline
post #2 of 11 (permalink) Old 04-14-2019, 09:09 PM
Ranger0297's Avatar
Bronco Info: 1989 EB 351w C6, 1995 XL 5.0 E4OD
Yes. When mine broke a couple of months ago I bought the metal ones. It is just one bolt that holds them on.
Sent from my SM-G960U using Tapatalk
anaconda likes this.
Hotty Toddy Gosh Almighty
Ranger0297 is offline
post #3 of 11 (permalink) Old 04-14-2019, 09:18 PM Thread Starter
anaconda's Avatar
Thanks I will pick up a set tomorrow. Did you have to pull the door panel or can you get to it with it on? I haven't really looked at it at all.
anaconda is offline
post #4 of 11 (permalink) Old 04-14-2019, 11:50 PM
fordbronco1995's Avatar
Bronco Info: 95 Ox White/Blue Int 5.8L 2 Level 33" Ridge Grapplers 17x9 M/T Classic IIIs Punisher Valve Body
You may be able to get a socket in the cutout but will be easier to pull the door panel, also pay close attention to where the handle mechanism mounts to the door, the doors are notorious for cracking in that area from the stress of the handle being used. Solo motorsports makes a reinforcement plate to eliminate the problem.
https://www.solomotorsports.com/shop...-repair-plate/
BigBlue 94 likes this.
EVERYTHING MANUAL EXCEPT THE TRANSMISSION:
fordbronco1995 is online now
post #5 of 11 (permalink) Old 04-15-2019, 04:22 PM Thread Starter
anaconda's Avatar
Thanks I checked and think I can just remove the bolt without pulling the door panel. My doors open smooth so should be ok not needing that plate. Good info to have in case.
anaconda is offline
post #6 of 11 (permalink) Old 04-15-2019, 04:55 PM
Ford Hoarder
The cables also stretch over time, something else to check if you pull the panel.
Or if at later date the door becomes hard to open with the metal handles.
Swapping of the handles is one of the first things I do when I get one of these trucks.
CrazyBRONCOguy is online now
post #7 of 11 (permalink) Old 04-15-2019, 11:10 PM Thread Starter
anaconda's Avatar
The door has opened with no problem since I got it. Then yesterday morning I noticed it came up higher than normal when I opened it. Yesterday afternoon it just came off in my hand. At least the door opened. I watched a couple how-to videos to get a good idea of whats behind the door panel. I'll start with just the handle and go from there. I guess 23 years of baking in the Florida sun inside a black vehicle isn't bad.
anaconda is offline
post #8 of 11 (permalink) Old 04-16-2019, 08:22 AM
Yo anaconda,
In 1996 Bronco, F-150, F-250, F-350, F-Super Duty Workshop Manual, partial @ 1996 Bronco/F-Series Workshop Manual
See Section 01-14A: Handles, Locks, Latches and Mechanisms
"REMOVAL AND INSTALLATION
Handle, Inside Door, Front and Rear( miesk5 Note, rear is for the F series models)
Removal
Remove one screw and remove inside door handle (22600).
Installation
Position inside door handle on front door latch remote control and link (21818) and secure with screw."
LVSteve likes this.
post #9 of 11 (permalink) Old 04-16-2019, 02:33 PM
Bronco Info: 1993 Bronco XLT / 5.8L / Auto / MAF Conversion / Hydroboost / D60/Sterling 10.25 conversion
Get the older metal ones. My Driver's side broke on me and I found out that pre 92 had metal handles (maybe even earlier, I can't remember). They're a little more expensive but well worth it!!!
https://www.amazon.com/APDTY-Interio...93+Ford+Bronco
MarktheShark is offline
post #10 of 11 (permalink) Old 04-16-2019, 04:36 PM Thread Starter
anaconda's Avatar
Thanks everyone. I picked one up today. Got the metal one and it only took about 5 minutes to change. They didn't have the passenger side. It isn't broke but figure I'll get it and change anyhow. It is an 8 mm bolt if anyone stumbles on this thread .
fordbronco1995 likes this.
anaconda is offline
post #11 of 11 (permalink) Old 04-17-2019, 10:57 AM
Wild Cayuse
The metal handles are great! I've broke a number of the plastic ones. You can get the metal ones in black or chrome. Much better than the 1/2" metal strap I used one time lol
July, and September!
FOTM forum section
BigBlue 94 is offline
You may not post replies
