Valve covers - Page 2 - Ford Bronco Forum
 21Likes
post #21 of 23 (permalink) Old 03-25-2019, 03:11 PM
Take the upper intake off on a injection engine, I know that. I use brake clean, rags to get the rails dry and use Fel Pro rubber gaskets glued it with Permatex non hardening aircraft sealant or 33 weatherstrip adhesive.
post #22 of 23 (permalink) Old 04-02-2019, 07:55 AM
bsd4083's Avatar
Bronco Info: 87XLT EFI5.0 flattop pistons, cam, SD, MSDIgn,aod,1356, 3g, Eaton-posi3.55,31X10.5, PCVswp
Wink
Originally Posted by TheHalfJamaican View Post
My engine leaks like a sieve. The blow-back from the valve cover gaskets is so bad, it covers the engine within a week with me washing it. Also, my drain plug leaks because the idiot who owned it last cross threaded the bolt hole. I've been meaning to replace the valve cover gaskets and oil pan gasket for a while now, but it seems like a lot of work. So hopefully, when I have a few hours to tear down the engine, I'll clean off the covers, replace all 3 gaskets, re-thread the drain hole in the oil pan, then repaint both the pan and the valve covers.
FYI FROM AMAZON YOU CAN BUY THE EXACT HEAVE DUTY VALVE COVERS LIKE IN THE VIDEOS I POSTED FOR 129$ A STEAL AND THE WARPING/ BENDING FLIMSY TIN VALVOVE COVERS CAN BE HISTORY AND THE GASKETS HE USED WERE AWSOME STEEL CORE--COATED IN RUBBER.
BEST WISHES
Wrencher61 likes this.
SARA CONNER lives in Kansas
bsd4083 is offline
post #23 of 23 (permalink) Old 04-02-2019, 01:59 PM
Wild Cayuse
Holy thread revival batman!
For my 300, I have quite the setup on the valve cover. It goes like this:
Felpro rubber gasket, 1/4" aluminum spacer, cork gasket, silicone, cork gasket, valve cover. The corks are held in place well by slits on the valve cover. The corks were siliconed together to create one piece. I had to do all this to clear my roller rockers.
bsd4083 likes this.
July, and September!
FOTM forum section
BigBlue 94 is offline
You may not post replies
