Ford Bronco Forum - View Single Post - 96 ford bronco distributor help!?
post #4 of (permalink) Old 01-24-2019, 12:16 AM
Festus
I'm not sure exactly what you are trying to accomplish, but here are a couple of links to RockAuto. They may help you find what you are looking for. The type of gear on the distributor is also engine specific. I'm not sure which you would need, cast or steel. I believe the 89 is an internal module while your 96 would have the module mounted on the fender. I would think you would need the 96 distributor with the correct gear for a 89 5.8 to match the wiring harness of your 96. Good luck!
96 info
https://www.rockauto.com/en/catalog/...stributor,7108
89 info
Festus is offline
