post #106 of (permalink) Old 02-13-2019, 03:38 PM
cobrajoe
Ford-a-Holic
cobrajoe's Avatar
Originally Posted by reptillikus View Post
Ill watch that vid in a little bit
I was using heat & water but no hammer work since its behind the regulator, not much room to swing. Also, the door has i guess fiberglass reinforcement on the inside, i assume to keep the mirror from flopping around in the wind. Guess ill have to try a little harder.
I'm thinking you should be heating,hammering and cooling the area in front of and behind the patch, not where you welded it in.
Just my $0.02
MY BUILD THREAD
cobrajoe is offline
