Ford Bronco Forum - View Single Post - Nasty noise from engine
post #23 of (permalink) Old 03-24-2019, 06:08 PM Thread Starter
end user
Bronco Info: 88
Ok so I ran a code reader just in case and I got code 67 O which says Neutral Pressure Switch circuit failure , circuit open (3.0L MAP, 3,0L MAF-SFI, 3.8L SFI)
Now I don't have an AOD in it anymore and have a C6 and I'm using a B&M Mega shifter with its own NSS. Not sure if this code has always been there since the swap since I only just checked it. Either way it wont start in N or in Park so I'm guessing its the Ignition Switch module thing on the column?
Werd!?
end user is offline
