Ford Bronco Forum - View Single Post - Nasty noise from engine
post #24 of (permalink) Old 04-14-2019, 07:24 PM Thread Starter
end user
Bronco Info: 88
Ok well I installed a new ignition switch on the column, made sure it actuator went in all the way but no ****ing go. So not sure wtf can be the issue? Are there are electronics that require the NSS to have a signal before power is sent to the S wire from the ignition switch?
Also is the tumbler suppose to spring back a bit after letting go of the key when the truck starts? LOL don't ever remember how its suppose to act.
For now I need to get the push button going as I'm gonna need the truck here and there in the next two weeks. Which hot on key wire can I use for the push button to the S terminal?
Werd!?
end user is offline
