Ford Bronco Forum - View Single Post - Nasty noise from engine
post #25 of (permalink) Old 04-14-2019, 08:48 PM Thread Starter
end user
Bronco Info: 88
Ok figure it out. I'm guessing actuator is bent. I didn't think of it as I replaced it a few years ago and couldn't imagine it bending or breaking so fast.Well it moves the rod but I guess the piece the rod sits in must have bent.
What I had to do it take the ignition switch off the column put the key to run and then use a screw driver to push the slider on the ignition switch all the way and the truck started :)
Now the fun part of taking apart the column once again.
Werd!?
end user is online now
