post #17428 of (permalink) Old 04-21-2019, 02:42 AM
youngDUMP
youngDUMP's Avatar
Bronco Info: 1989 EB Bronco, 5.0, AOD, 4" lift, 35" tires, 4.56s
Originally Posted by Wrench85 View Post
Reattached the passenger armrest but now it gets tight spots... I think I might be missing some hardware... is there more than just the bolt and the washer that clips onto it?
Iirc my 89 EB seats had a nylon spacer (about as thick as a garden hose gasket) between the armrest and seat. So seat, nylon washer, armrest, clip washer, bolt. The center of the nylon washer was wide enough for the shoulder of the armrest bolt to pass through. Itís purpose seems to be to provide dry lubrication at the hinge. I made one from a nylon washer kit from the zone. Had to bore the center out a little with a step bit and clean up with razor blade.
IG @schaeferlight
youngDUMP is online now
