post #17444 of (permalink) Old 04-24-2019, 11:08 PM
klh95bronco
klh95bronco's Avatar
Finished up installing a factory transmission oil cooler I scavenged out of the junkyard the other day. The lines were intact so I got those too and used them.
I also put in a secondary filter in the return line back to the transmission to help keep my transmission fluid nice and clean.
I got everything assembled and tightened down and gave her a test run. Everything checked out good and leak free. I believe I have about $70 invested in the cooler and filter setup.
I used my temp gun and checked the oil cooler temp and it registered between 160-170 degrees.
This will definitely help for the long haul out to Moab next week and the extra heat generated out on the trails.
Kenneth
klh95bronco is offline
