post #141 of (permalink) Old 05-09-2019, 05:07 PM Thread Starter
reptillikus
Originally Posted by fodder View Post
What's your technique for shaping the ends where the tubing meets? Just lots of grinding and checking? I just did some of that and found it to be slow going, with imperfect results.
I usually just eyeball it
The center hoop, i have a jig for cutting the angles on that one, that i built years ago when making tube steps for a quad-cam ram. So i just set the hoop in there, and adjusted it til the angle was right. So no real thinking involved in that one.
The two on the end, one is a mirror image of the other. The first one was the driver side; i eyeballed it and cut it, and was damn near on in the first shot. The bottom end needed a second cut, the top end just needed some minor grinding. Then bent the second, copied the angles over to it, and mirrored them. I wish i could say theres more to it, but not really. Its just that ive done it a couple times before, and already knew roughly what theyd look like when cut. Ive used the paper trick before and it works pretty good, but not on such a heavy angle like the top has. You can get contour gauges that get you pretty close pretty quickly as well, but theres definitely an art to it i think. Usually i can get it pretty close on the first shot, but ive also made a lot of mistakes on cuts over the years too No angle finders; i find it easier and quicker to just eyeball it, and do some minor grinding if need be.
All that said, i spent probably an hour on those two pieces, but that does include setting up the smaller die in the bender. Once i had the shape, the second went quickly.
I bought one of these (carbide tipped sawzall blade), which has been a huge help in building the front bumper. Yes only one, and yes its still going strong. It seems its going to last forever, and makes nice straight cuts quickly.
reptillikus is offline
