Ford Bronco Forum - View Single Post - 1985 All-Purpose Build
post #4 of (permalink) Old 05-15-2019, 01:31 PM Thread Starter
BigBlue 94
Wild Cayuse
Next up my gauges.
My speedometer itself was making terrible noises, then the needle fell off!
Insurance from the fire bought me a full set of Autometer gauges.
- GPS speedo
-tach
- fuel level
-oil psi
-water temp
-voltage
- Wideband AFR
- 2 Differential temps
I decided to mount them in the factory spot, and the factory bezel. Made up a main pod, and 2 dual side pods.
I sprayed them with a coat of bedliner for texture, then normal black spray paint.
Then came the actual wiring. Here's my kindergarten wiring diagram
Also added blinkers, high beam indicator, and warning lights for the oil psi and water temp.
Full thread on gauges
https://www.fullsizebronco.com/forum...85-bronco.html
July, and September!
FOTM forum section
BigBlue 94 is online now
