Ford Bronco Forum - View Single Post - 1985 All-Purpose Build
post #10 of (permalink) Old 05-15-2019, 05:57 PM Thread Starter
BigBlue 94
Wild Cayuse
I also upgraded the fuel lines. I currently have both an electric pump and a mechanical pump. The electric one was added by the PO, and is manually operated by a switch on the dash. I never use it. The pump is located under the driver seat, on the frame rail. From there, I converted to -06AN braided stainless line. I used Earl's brand hose, and a combo of Earl's and Summit fittings. I have two filters, first a huge 100 micron filter, then a good sized 10 micron filter. They feed a 35 gph mechanical pump and then an aeromotive fuel pressure regulator set at 6.5 psi.
100 micron KRC filter
Hose assembly with a KoulTool
The 10 micron filter
Both filters in their places
Up to the pump
And over to the FPR
And, 300 owners will notice, I ran the line around the back of the engine, instead of over the valve cover.
July, and September!
FOTM forum section
BigBlue 94 is offline
