post #17497 of (permalink) Old 05-16-2019, 08:47 AM
ctandc
Got the new hub in. It comes with new bearing races installed. Confirmed they are the same PT# as the ones that came with my Timken bearing sets. Got it cleaned out (machine oil) inner bearing packed / installed, cavity greased, inner wheel seal installed and used the new wheel studs to get the rotor pressed on the hub. Everything ready to go back together FINALLY.
__________________
ctandc is offline
