Ford Bronco Forum - View Single Post - My name is snowman429......
post #7 of (permalink) Old 07-19-2019, 03:58 PM Thread Starter
snowman429
snowman429's Avatar
Bronco Info: Where to start?? 93 Bronco
[QUOTE=Blue1551;7226044]This is my take. Pull the entire drive train replace with LQ9,4L60 bullet proofed and a 4 speed atlas. SAS James Duff, with 1 ton's running 5.13s, lockers with bead locks. Replace the steering box and pump from the F350 you got the 1 ton's from. Install full role cage, sliders, stout bumpers and a 12000LB. wench (not HF).
This all needs to be done by Apr 26th 2020 so you and family can come to MOAB for the Bronco invasion 2020. You have 9 months easy build you can make it. Great time and even better people.
Just my thoughts[/QUOTE
Sounds like a good plan but, I need to get mine, my sons, and my wifes painted before I can start this one
93 Bronco, long travel ttb,Threat motorsports 4.5" wider beam and extended radius arms,14" coilovers strapped at 18" of travel.9" fabricated dutchman trussed housing chromoly axles detroit locker 4:88 gears,Threat motorsports underbed shock mount with 12" triple bypasses also strapped at 18" of travel Fully caged, Mcneil fenders and bedsides.35"general grabber red lables on stock factory Alcoas. 408W stroker topped off with a Holley sniper efi. No HP numbers but she moves.
snowman429 is offline
