Ford Bronco Forum - View Single Post - 130 amp 3G with v-belts
post #10 of (permalink) Old 08-05-2019, 11:55 AM Thread Starter
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Originally Posted by SRWillis View Post
No problem. I forgot you did the Sag swap, I see what you mean...
Since it's squeal-free with the new single belt, I would leave it set up like that and get a soft start regulator and maybe it will stay that way
I might look into that. I saw the part number listed on one of the links you provided.
I'll also look into a better belt. This is just a cheapie $2.99 belt to see if I could get it to work. A high quality Gates or something would last a lot longer, and have some better grip.
May 2019 FOTM
March 2016 FOTM
1981 Bronco Custom (R.I.P.)
Supermotors Pics
AbandonedBronco is offline
