Ford Bronco Forum
Ford Bronco Forum (https://www.fullsizebronco.com/forum/)
-   1980-'96 Bronco Tech (https://www.fullsizebronco.com/forum/7-1980-96-bronco-tech/)
-   -   Post a picture of your engine 80-96 !! (https://www.fullsizebronco.com/forum/7-1980-96-bronco-tech/262281-post-picture-your-engine-80-96-a.html)
Saltlife 10-22-2013 04:32 PM
We have a thread in the 78-79 tech section so I wanted to post a thread for us here for our 80-96s. Post up a picture of your engine. Show off what you have under the hood. ;)
Post pictures of your engine out or in the bronco only. No Please no chit chat. :beer
Mine:
Old In:
http://i1082.photobucket.com/albums/...224_171343.jpg
Out:
http://i1082.photobucket.com/albums/...2_120238-1.jpg
Rebuilt out:
http://i1082.photobucket.com/albums/...410_171521.jpg
http://i1082.photobucket.com/albums/...409_174424.jpg
Now:
http://i1082.photobucket.com/albums/...019_113629.jpg
95bronco12 10-23-2013 05:43 PM
Travisfab 10-23-2013 06:28 PM
Evan_P 10-23-2013 08:25 PM
http://www.supermotors.net/getfile/1.../img_13181.jpg
http://www.supermotors.net/getfile/1.../img_13201.jpg
Ignore the duck taped airbox. It is being MAF converted this winter so the air box will be changed. What really matters to me though is than it runs great and gets me where I need to go.
thin blue line 10-26-2013 02:38 PM
here's the one i am going to put in my 95 its a ac delco re manufacture 302. i am going to swap my e7 heads, explorer cam, upper and lower intake over to it and let it eat..
http://i1135.photobucket.com/albums/...0-02153220.jpg
ANGELO 10-27-2013 05:30 PM
Scoop 10-28-2013 10:15 PM
OK awesome, made the first page of this sticky!! First 6 cyl too!
Here's my 84 300 I6:
https://s3.amazonaws.com/ClubExpress..._234300241.JPG
https://s3.amazonaws.com/ClubExpress..._190483581.JPG
I'm loving the simplicity of the I6!
cajunrebel 11-02-2013 01:00 PM
http://www.supermotors.net/getfile/9...e/imag0175.jpg
On the stand after a rebuild. 5.0L 89 block, converted to OBDII using parts from a 96 F-150 with an E4OD. Had 249K miles on it and only went down because the cooling system was full of rust from the PO.
http://www.supermotors.net/getfile/9...e/imag0173.jpg
Same motor prior to painting.
http://www.supermotors.net/getfile/9...e/101_0134.jpg
Its dusty here after sitting for a year in the desert, but has since been cleaned.
miesk5 11-02-2013 01:17 PM
yo, 96 5.0
http://www.supermotors.net/getfile/6...wconnector.jpg
Differential Pressure Feedback (DPFE) Location pic in a 96 5.0; Silver Rectangular item, driver's side next to distributor - MIESK5 NOTE: only 95 5.8L California models & all 96 have the DPFE Sensor instead of EGR Valve Position Sensor (EVP)
http://www.supermotors.net/getfile/1...ize/plugs1.jpg
96 5.0 Plug Wire Routing on Driver's Side
http://www.supermotors.net/getfile/1...ize/plugs2.jpg
96 5.0 Plug Wire Routing on Driver's Side low
http://www.supermotors.net/getfile/1...ize/plugs6.jpg
96 5.0 Plug Wire Routing - distributor view
http://www.supermotors.net/getfile/1...ize/plugs5.jpg
96 5.0 Plug Wire Routing on Passenger's Side; at & below distributor
jeeptoFSB 11-04-2013 12:57 AM
http://i415.photobucket.com/albums/p...103_025919.jpg
1984 Ford 302 AC Delete, Weiand Intake, Carter AFB Comp 4bbl 625cfm, Accel Super Stock Coil, Duraspark II and a Big A$$ K&N
http://i415.photobucket.com/albums/p...103_025948.jpg
Oscar 11-07-2013 02:42 AM
NWTF 87 11-08-2013 10:18 AM
NWTF new horses
Gacknar 11-08-2013 10:30 AM
beniflas 11-08-2013 10:48 PM
Another dirty 5.8...I'm hoping this will someday be a "before" picture. I did clean up quiet a bit of rust from what looked like a bad radiator leak from PO.
http://img.photobucket.com/albums/v4...ps770b475f.jpg
AFBronco235 11-09-2013 08:45 PM
1 Attachment(s)
91' 5.0L
Bronco84-Mart86 11-12-2013 01:58 PM
My engine before;
http://www.supermotors.net/getfile/1...3112009113.jpg
http://www.supermotors.net/getfile/1...3112009105.jpg
After;
http://www.supermotors.net/getfile/1...0022010185.jpg
http://www.supermotors.net/getfile/1...0022010186.jpg
And now
http://www.supermotors.net/getfile/1...e/img_0667.jpg
http://www.supermotors.net/getfile/1...e/img_0668.jpg
Some more pic's on http://www.supermotors.net/registry/24276/82322
and some spec's:
351 CID Windsor engine,
Edelbrock performer plus cam 2182,
Edelbrock True-Roller timing chain 7811,
Edelbrock performer monifold 21813,
Edelbrock Thunder AVS 650cfm Carb 18064,
Edelbrock Round Elite series air cleaner,
MSD Pro Billet Distributor 8354,
MSD Super Conductors 8,5mm 31239,
MSD, MSD High Performance Blaster 2 Coil 8202,
High volume oil pump, alu watepump,
Removed the CA EGR system,
351W script valve covers.
remco 11-12-2013 06:19 PM
cold steel 12-04-2013 11:20 PM
huggyb1972 12-04-2013 11:49 PM
BikerPepe` 12-05-2013 12:26 AM
The old '89 "Stoned Bronco", ready to remove the old 351
http://www.supermotors.net/getfile/1...d-bronco-2.jpg
out and ready to strip for the next block...
http://www.supermotors.net/getfile/1...engine-out.jpg
new block... now ford blue, to match my thumb. :thumbup
http://www.supermotors.net/getfile/1...d-blue-(1).jpg
ready to go back in. unfortunately, I never got a good shot of it fully installed for some reason. :banghead
http://www.supermotors.net/getfile/1...sembly-(5).jpg
think this is as close as I got...
http://www.supermotors.net/getfile/9.../zakengine.jpg
and here's the '90 302, from the craigslist ad... not a great shot either.
http://www.supermotors.net/getfile/1..._cl_ad-(4).jpg
:whiteflag
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
