Ford Bronco Forum
Ford Bronco Forum (https://www.fullsizebronco.com/forum/)
-   Suggestions, Feedback & Site Help (https://www.fullsizebronco.com/forum/19-suggestions-feedback-site-help/)
-   -   How to use search (Advanced) (https://www.fullsizebronco.com/forum/19-suggestions-feedback-site-help/62157-how-use-search-advanced.html)
Gacknar 02-15-2006 02:31 PM
This is where the Advanced search function is located. (Under the Tools Tab)
It appears in almost every page you could go to on this site.
Click on it to enter Search
http://www.supermotors.net/getfile/1...w-search-2.jpg
If you want search by user name enter it here.
The pull down menu can be switched between threads started by user or post by user.
"Posts by user" will find every post ever by a user
"Threads started by" will only find threads started by the user.
http://www.supermotors.org/getfile/2...al/search2.jpg
This is where you would enter a key word if you wanted to search by key word.
The pull down menu can be switched from "Search entire posts" to "Search thread titles only"
"Search entire post" will search the entire contents of every single thread on FSB.
"Tittles only" will just search the thread tittles
http://www.supermotors.org/getfile/2...al/search3.jpg
Find threads with
If your only interested in threads with many replies, you can set that option here.
If your only interested in threads with few replies, you can set that here too.
http://www.supermotors.org/getfile/2...al/Search4.jpg
Find posts from
If your only interested in newer posts, you can set that here.
Same with older posts.
http://www.supermotors.org/getfile/2...al/search5.jpg
Sort results by
This has two panels to choose from. The first one sorts the order by groups.
http://www.supermotors.net/getfile/4...al/search8.jpg
The second changes the order of the search results from highest to lowest or oldest to newest and vice versa depending on the criteria you set in the other "Sort results by" window.
http://www.supermotors.net/getfile/4...al/search9.jpg
Show results as
You can pick either threads or posts.
Threads will show each thread as you are use to seeing it, click on the thread to read the posts.
Showing them as posts will show you the actual post in the thread that has the keyword or user name you are looking for. It will have a link to the thread and a link to start the thread at that particular post
Search in forum.
This lets you select which forums you want to search in.
Say you want info on a 351m, you could set the search to only look in 78-79
http://www.supermotors.org/getfile/2...al/search7.jpg
Sorry for the big picks, it was the only way to keep them clear
miesk5 07-18-2006 09:29 AM
btw, how is a search entry performed for posts older than one year?
I was just searching for an old post I made, but the search section; "Find Posts from" only goes back to one year.
I know the archives are avail., but is there a search function for these too?
btw, I found my post by Googling my name and the short tite of the subject I was seeking
and what is "Also search in child forums"?????
Gacknar 07-18-2006 10:59 AM
By doing a regular search with your name and the title of the thread. Every post you ever maid will be found. At the bottom right of the first page there will be a list of page numbers. If you know it was over a year ago click a few pages out and see what the date is, you can go all the way back to your verry first post.
Thats just a standard V-Bulliton thing for more family orented sights that might have forums for kids too.
dsotmoon 07-18-2006 07:50 PM
ummm, good answer, but not quite :histerica
"child forums" are sub forums, like a "child forum" of the anything else forum is the news&politics forum :thumbup
Redwagon 07-18-2006 07:51 PM
Hey...he tried...:histerica
Gacknar 07-18-2006 11:40 PM
Hey, I dont own the site....
I just pretend I do :toothless
Hey, Like Redwagon said.....I tried :histerica
1clean5.8 07-19-2006 02:51 AM
Can we place a tutorial on the welcome page that Noobs have to take before the site lets them post ? Just an Idea
dsotmoon 07-19-2006 07:23 AM
they have to read & "sign" (by clicking a check box) that they have read the rules, how to search, etc before posting in the help sections, as this is where the main problems usually are
miesk5 07-19-2006 09:20 AM
thanks, but try it, mine goes back only to 02-25-2006 03:17 PM
I tried all combos of entries in Search and trying "Any Date"; "and Newer" & "and Older", etc.
as well as Clicking User Name, "View Profile" & Find all posts by ____" & "Find all threads started by ____"
Haven't found any going back to at least 2003.
and way of searching Archives?
Gacknar 07-19-2006 10:46 AM
Just did, it went back to 11-08-2003 02:16 PM :shrug
miesk5 07-19-2006 12:38 PM
ok, what did you do to get back to 2003?
I did 3 searches for your name and oldest post was 06-13-2006, 05:50 PM
I'm using:
Search (in gray toobar)
Search Forums
Search by User Name
User Name: miesk5
Under Search Options;
Find Posts from
Any Date
Search in Forum(s)
Seartch All Open Forums
Search Now
miesk5 07-19-2006 12:49 PM
Also,
tried by clicking my user name in last post in this thread as described in above post.
miesk5 07-19-2006 02:39 PM
OK!
tried searching by "Key Word" instead of User Name and in profile...and got back to 03...thanks G for trying to help me; a bad brain day(s) here again for me.
miesk5 07-20-2006 08:36 AM
Maybe it's time to update this Search thread to show above search to get back to earlier years?
and same for search by Key Word
Gacknar 07-20-2006 09:01 AM
Search by key word is the second pic down.
And I didn't think I needed to cover "sort results by" because it just seemed self explanatory but I will update that as well.
But here is how to find your oldest post.
Put your name in the "user name" box and change second "sort results by" box to "Ascending"
http://www.supermotors.net/getfile/4...nal/miesk5.jpg
Hit search.
The oldest thread with your usure name will be the first one.
http://www.supermotors.net/getfile/4...al/miesk5a.jpg
There ya go :thumbup
Gacknar 07-20-2006 09:31 AM
"Sort results by" now appears in both of the tutorials. :thumbup :beer :chili:
miesk5 07-20-2006 02:26 PM
ok thanks!
Steve83 12-17-2008 05:51 PM
Two more points worth noting:
1) To search in several forums, hold down the CTRL key while you select them all.
2) To search WITHIN the text on a web page (here or almost anywhere else), click in the text area of the page, then hit CTRL+F <Find>, type your search criteria in the text field, and hit ENTER as many times as necessary. If you're looking for information about air conditioning, you might search for "ac", but that would find every instance of that pattern, including words like "Gacknar", "each", & "traction". So a better search term might be "a/c" but that might find electrical references, or "ir con" which would only find air condition... Graphic text (images), Flash movies, & some other web pages don't support this function.
White96 12-18-2012 05:06 PM
I realize this is an old thread but is there a way to search for a string, such as air conditioning? I was looking for suspension lift and it found all suspension, all lift, and suspension lift combinations. I would like to have narrowed it to just the suspension lift hits.
BikerPepe` 12-19-2012 07:59 PM
standard search query protocols require two (or more) separate words to be enclosed in "quotes" for specific hits to match both (and/or all) words in the query, instead of an either/or result.
try "suspension lift" and see if that helps narrow it down for you.
it appears that using the quote combo works, but confuses the script that ads the red highlight to the searched for text.
pretty large topic around here... I'd suggest adding a year or any other generic but narrowing terms.
enjoy... more info than you can shake a mouse at around here.
If no luck after a good search... feel free to hit the "Noobie Bronco Tech Questions. Flame free zone!" for questions and further references.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
