Ford Bronco Forum
Ford Bronco Forum (https://www.fullsizebronco.com/forum/)
-   Solid Axle Swaps (https://www.fullsizebronco.com/forum/29-solid-axle-swaps/)
-   -   Ultimate TTB coil adapters. (https://www.fullsizebronco.com/forum/29-solid-axle-swaps/76283-ultimate-ttb-coil-adapters.html)
90Beater 09-08-2006 08:19 PM
I made a set of coil adapters to fit TTB springs on solid axle a few months ago and a few guys liked the way they looked. They wern't bad but they lifted the Bronco a little too high. I also thought I could make them a little better. Here's a look at the original ones.
http://bronco.tophersworld.com/image...co_sas_029.jpg
http://bronco.tophersworld.com/image...co_sas_030.jpg
This is where they go. Between the radius arm and coil.
http://bronco.tophersworld.com/image...co_sas_031.jpg
A friend with a mill and lathe made these up for me. The new ones eliminate the two part adapter and should get the Bronco back to about 6" of lift when project SAS2 is completed.
http://bronco.tophersworld.com/image...l_adapter1.jpg
http://bronco.tophersworld.com/image...l_adapter2.jpg
Redwagon 09-08-2006 08:29 PM
wow those came out bad ass...
reptillikus 09-08-2006 09:28 PM
10 Attachment(s)
Nicey done :thumbup
ToddACimer 09-08-2006 09:54 PM
that's to run ttb coils on a solid axle? How are they for springs mounting without bow?
90Beater 09-08-2006 10:22 PM
The TTB springs seat differently than the solid springs. They can pivot so they don't have that problem. My old ones bowed differently because the axle ended up being pushed 1" forward of the top coil buckets. I had the two bolts moved forward on these mounts moving the axle back. there should be no bow now.
ToddACimer 09-09-2006 03:28 AM
I realize they seat different that's why I run the 79 Coils and I have no bow running all stock parts and no shims
plug ugly 09-09-2006 03:26 PM
very nice. tools rule
Drilim 09-09-2006 03:38 PM
Those are the cats ass.
mattabis 09-11-2006 03:19 PM
wow those are damn nice
i was wondering how well it worked without the bow in the first picture because this is the same route i took and i had to set mine back an inch or so i think it was an inch and a half from center. then i saw the second ones man those are cadillac!
crackhead 09-16-2006 03:25 AM
Are those built on the same measurements you sent me?? Ive really got ot get some of those built... Mine work ok, but I just dont like the way they look.. Those are tits..
90Beater 09-16-2006 02:16 PM
the only difference is I ended up using 5" stock to give a little more room for the bottom bolt holes.
bronconatic 01-31-2007 09:04 PM
how much did thoughs coil adapters add to your lift?? cuz i want to use my 4in ttb coils on mine
90Beater 02-01-2007 01:58 AM
The first set added about 2 1/2" to the lift which was a little to high for my liking. The new set should only be about 3/4". If you wanted more lift you could just have it made with a thicker base. I wouldn't want to go too high though. I would be afraid of snapping the bolts that hold it to the radius arms.
http://bronco.tophersworld.com/image...s_arms_009.jpg
TravisITGuy 02-01-2007 10:55 AM
so would these work with the cage arms ?
90Beater 02-01-2007 11:26 AM
As far as I know they would. I haven't seen the cage arms myself but as long as the two threaded holes on the C caps are the same it should be no different than stock.
One thing I posted in my SAS thread that isn't here is the top part should be narrower than in the dimentions I made. They were a litle too thick and I had to grind them down to fit the bottom of the coil. Where I had the top at 2 1/2" it should be 1 3/4".
http://bronco.tophersworld.com/image...ters_ver_2.jpg
4x4_Racer 02-01-2007 06:47 PM
I just have to say, VERY NICE!
bronconatic 02-01-2007 09:27 PM
how mcuh would you charge for a pair
90Beater 02-02-2007 01:40 AM
Actually I had them made. You can take the above pic to a machine shop and have them made. I don't know the cost it was a trade deal.
danielzink 03-07-2007 07:09 PM
Got Mine !
First off - I want to thank 90beater for posting the plans for these adpaters ! major props to him !
Anyhow - I took the plans posted earlier in this thread to a friend - who then referred me to a machine shop. I handed the guy my RA's, a spring and these plans here's what he fabbed up for me:
I'm definitely jazzed....
The plan is to use the TTB upper coil buckets with the Rough Country 4" springs (hoping to net 6" of total front lift). Stock (79) bronco drag link & trac bar, 7* c bushings, Existing drop pitman arm.
And fabricate a trac bar mount.
http://pws.cablespeed.com/danielzink/PICT0989.JPG
http://pws.cablespeed.com/danielzink/PICT0990.JPG
http://pws.cablespeed.com/danielzink/PICT0991.JPG
http://pws.cablespeed.com/danielzink/PICT0992.JPG
http://pws.cablespeed.com/danielzink/PICT0993.JPG
http://pws.cablespeed.com/danielzink/PICT0994.JPG
http://pws.cablespeed.com/danielzink/PICT0996.JPG
Dan
90Beater 03-07-2007 07:19 PM
very nice. I like the way they machined it so the bolt seats in but cant turn.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
