1 - 3 of 3 Posts
Charlie don't surf..
'92 Ford Bronco XLT
Looks like crownvic.net is down, so I figured I'd check here..my '03 CV has the EATC. A/C blows ice cold, but recently I noticed that every so often the A/C would switch from the vents to defrost, completely at random..
I ran the EATC self test and didn't get any codes. The blend door module was replaced about 5 or 6 months ago..
Anyway, does this sound like a vacuum issue? I know the EATCs have had issues with the o-rings, and with mine being 12 years old it's probably due..
Just wanted to double check before I drop the $$ on replacement..Thanks.
Banned
The "E" in "EATC" means electronic, so I wouldn't expect it to use vacuum for anything. Have you actually found vacuum lines going to that control panel?
'92 Ford Bronco XLT
yes it does mean electronic. however it relies on these 4 solenoid mechanisms within the module to control the various HVAC features, they use o-rings..there is a vacuum manifold on the back of the module..
1 - 3 of 3 Posts
