1 - 9 of 9 Posts
What all would I need to do to put 06 f250 axles under my 78 bronco I found a set for $500 ?
If these are the coil spring variety, RuffStuff has a kit to install them on any vehicle - this is not bolt on - you need to be able to fabricate.
The rear just needs new leaf spring perches properly spaced and angled.
You will need at least conversion u joints and possibly modifications to your drive shafts.
You will need new wheels.
Addicted to Junk
The 05+ dana 60 and sterling 10.5 are significantly stronger than the 97 and prior stuff. You will have to get new wheels, due to bolt pattern and brake size. The smallest wheel you can run on those is a 17".
@curtwow has a dually set under his 79
Ford Hoarder
78 & 92
Opinions vary on this. To me the old dana 60's are overpriced for dated technology. If I was going to the effort of putting one ton axles in my bronco it would be the Superduty set like you where asking about.
Bigger brakes, easier to find parts, disc brakes stock. Also can get the factory elocker for rear too. Are some of the reasons I say this
Addicted to Junk
I tend to agree. The new 05+ stuff is leaps and bounds above the previous models. Even the axle tubes are thicker and bigger in diameter. I have a NIB e-locker for a sterling 10.5 on my shelf. At ~$600, it's the cheapest selectable locker around. It can be made to work in a 10.25 though too.
However, the JY doesnt care what it is from. Either a 96 or 2008 axle is the same price. I've got two 97 and back d60s, just $200 in each one. One is going in my 88 f250 which already has the sterling 10.25 with 8x6.5 bp. So sometimes, the older stuff is fine. The one thing I dont like about the 05+ axles is the huge radius arm mounts. But some chopping and welding can fix that.
154549
05+ D60 knuckle vs OBS you tell me which is a better axle. Get the frame mounts for the coil springs and shocks and the arm I can remember name of.
Addicted to Junk
1 - 9 of 9 Posts
