1 - 20 of 24 Posts
Sorry for the noob question but how do i tell if its a full float or semi float?
so how do i tell just by looking at it? And is the semi float worth having?
what part of the axle do you need a pic of? and is the semi float worth having. Ill be running a 393 with sd and probably 35's with 4.56
Administrator
2012 Jeep JKU
take a shot of the wheel/hub area...I really dont know the strength of the semi-float but my understanding is the full floaters are pretty strong, just like the chevy 14 bolts, just remember its a 8 lugh hub.
Discussion Starter · #9 ·
yeah im doing a front axle swap as well. I bought a sterling for 100 bucks. And didnt do my research.
User that is Registered
A semi float axle won't have anything poking out where the wheel attaches, like on your stock rear axle.
A full float axle will have a hub poking out through the wheel, similar to your front axle (minus the lockout)
I would buy something else, the full floater design is stronger, easier to service, safer, and has better parts availability, based on what I have seen in junkyards.
The semi floater is lighter and may be plenty strong for you though, search more and decide for yourself.
Banned
A full float axle won't have anything poking out where the wheel attaches, like on your stock rear axle.
A semi float axle will have a hub poking out through the wheel, similar to your front axle (minus the lockout)
You just said it backwards.
full float=hub sticking out
semi= no hub, looks like the center of a 8.8.
Convicted Drunk Dialer
I wouldn't waste the effort in swapping it in to anything when the full floats are so easy to find.
:stupid
They are a dime a dozen, at least around here. Incidentally, I have a couple sets of 4.10 gears and a track-lok that need a new home. ;)
:stupid
ditto. Unless youre getting this thing and a rebuild for free or something dont do it.
1 - 20 of 24 Posts
