I have an 1988 with AOD Trans and need to rebuild the BW 1356 shifter. Is there anywhere to find parts for it or will it just need to come apart and be cleaned? Also need a knob. LMC just has a latter model rebuild. Is there an aftermarket shifter that will work? Thanks
I thought there were just some nylon bushings inside the joints on the T case linkage? I just took mine apart , then gave everything a good greasing before reassmbling it. What part of it is worn out do you think?
I am not able to pull the transfer case into gear sometimes and always with difficulty. Impossible to hit four low. A heavy dose of break-free gets it to move.It would be almost easier to shift the case by just taking off the linkage and using a wrench. If it is as you say just, some bushings, where do I get them or what would be your solution?
Ford may have them. Or like I was saying take them apart and grease them really well. You could even fit a grease zerk onto the joints if you wanted to. The bushings look just like a nylon plug with the bottom cut out and a slice down the side. I used just what I described to replace one of mine after I lost it. The plugs I am talking about come in new parts that have ports in them . Most of the time they are a blue or red in color.
yo,
One source is http://www.motivegear.com/pdf/LD_TRANSCAT_004_1.pdf
see pages 214-215
44/56 1350100001 SHIFT RAIL
45 1356127008 BUSHING - SHIFT CAM
46 1356599001 SHIFT CAM - LATE STYLE SPLINED
47 1356598008 SHIFT LEVER - CURVED - NO SHAFT
47 1356598009 SHIFT LEVER - STRAIGHT - SPLINED SHAFT
47 1356598007 SHIFT LEVER - STRAIGHT - SET SCREW SHAFT
47 1356598006 SHIFT LEVER - STRAIGHT w/o SHAFT
47 1356122001 SHIFT SHAFT ONLY
see more parts
http://www.allstategear.com
http://www.behemothdrivetrain.com/Transfer_Case_Parts.html
http://www.rsgear.com/technical/dia...rner-1354-transfer-case-mechanical-shift.aspx
- Bronco/Ford truck new & used transmissions, clutches, flywheels, differentials & transfer cases; shifter knobs
1356 Manual Shift Rebuild in 87-91; "...This will be for a manual shift T Case 1356 from an 89 should cover 87 threw 91 . 92 through 96 are not equiped to drive a speedometer cable so the back case cover is a bit different..."
Source: by BLADE262US at Ford Bronco Zone Forums
1356 Manual Shift Shifter Linkage for AOD & E4OD; "...The AOD mounting plate and actuator arm are both different. The E40D arm is longer. A new arm could easily be fabricated. The AOD mounting plate could easily be made to fit the E40D transmission. There are basically 3 parts. Shifter, mounting plate with shift detents, actuation arm. The mounting plates are different; but, if you have AOD could be modified by welding on more surface area and redrilling the mounting holes. The EOD actuation arm is longer. The Shifters are the same for both. had some trouble finding linkage; most people don't want to sell the E40D linkage without selling the entire transfer case..." see pic Link
Source: by Dastad at FSB
1356 Manual Shift Shifter Knob Replacement; In my 96's Workshop Manual, Ford only says this about da BW 1356 Transfer Case Shifter Knob; "Prior to installation, the gearshift lever knob must be at room temperature and may be warmed to 60°C-82°C (140°F-180°F) as an assembly aid..." never took it off, but others have said it is pressed on to the splined shaft. And use a hairdryer to soften it for removal, exactly as Ford describes for installation!
For a YARD SEARCH on-line, I use;
http://www.mypartshop.com
Select All Parts
year, etc, then FORD TRUCK
Some Results for TN
87
BRONCO Transfer Case Assy
A 180 9J968
190217 0.0 Call 34 Call Turner Auto Salvage
931-668-4157
800-821-8775
Turner Auto Salvage
Anthony or Charles
931-668-4157
800-821-8775
2421 Nashville Hwy
McMinnville TN 37110
[email protected]
88
5.0 AOD 412-00381 194 5E718
62375 0.0 Call 34 Call Turner Auto Salvage
931-668-4157
800-821-8775
Turner Auto Salvage
Anthony or Charles
931-668-4157
800-821-8775
2421 Nashville Hwy
[email protected]
87
5.8 AT 0 6981
87552 0.0 $200.00 46 Call Tennessee Auto Salvage
615-384-5033
800-242-7927
Donna or Matt
615-384-5033
800-242-7927
2082 Duncan Lane
Greenbrier TN 37073
TENNESSEEAUTOSALVAGE.COM
89
E8TA BA CODE BOLT ON REAR YOKE 156 003206
61548 0.0 $650.00 80 Call Complete Auto Parts
256-776-2951
800-633-2990
http://www.copartfinder.com/finderHome.do
HAS PICS!!!
and;
http://www.picknpull.com/locations.aspx
