1 - 1 of 1 Posts
Car and Driver put this list together that highlights some of the unique features on the Bronco.
Headlights
2021 ford bronco
The first thing you'll notice about the Ford Bronco are these giant circular headlight housings. They're big, but they aren't new. In 1965, when the first-generation Ford Bronco debuted, it wore giant circle halogen headlamps with smaller amber signals just to the inside of the grille. We suspect the design of the new Bronco carries that similar DNA, but this will also help the truck look less like a Jeep at night.
Fully Torx
2021 ford bronco
The shiny hardware holding parts of the dashboard and the rest of the interior together are aluminum Torx bolts that read Bronco, MNP 8.8. A metric bolt that's the equivalent of SAE Grade 5 hardware.
Bucking Bronco
2021 ford bronco
The big bucking bronco has been fixed to the Ford Bronco since its first days back in the mid-1960s. Although the horse has changed its dance over the Bronco's lifetime, today it's kicking harder and higher than ever. Ford’s ad slogan for this debut is "Built Wild." The bucking bronco’s rear hooves are lifted, unlike the Ford Mustang pony that looks like it's running to a trough full of apples.
Inclinometer
2021 ford bronco
Nearly as wide as the 1980s Bronco II’s 15.0-inch wheels, an available 12.0-inch touchscreen system features off-road trail navigation that works without cell service. It’s also host to other off-road assistance, including an inclinometer that shows you how sideways, forward, or completely backward an incline you're at while climbing crazy terrain. The inclinometer shows a first-gen Bronco doing sixth-generation Bronco stuff.
Designed & Engineered
2021 ford bronco
Both the two-door and four-door models of the 2021 Ford Bronco will be built at the Michigan Assembly Plant in Wayne, Michigan. The design work, however, took place about 20 miles east at the Blue Oval's offices in Dearborn, Michigan.
Taillights
2021 ford bronco
Here the design team nailed a bunch of personality to a baseball bat and beat the new Bronco senseless. Nothing else looks similar, not even the Jeep Wrangler it hopes to defeat. Like the round headlights, its thin vertical taillights are pure Bronco. Unlike earlier Broncos, the new one is chock full of LED lights, but the sharp edges at the bottom of the lights are similar to what the older trucks had. Even the white reverse lamp sits deep inside the housing, like before. The placement of the blue oval at the lower right of the tailgate is also a big 1990s Bronco vibe.
Go Over Any Terrain
2021 ford bronco
The original Ford Bronco was nicknamed the Go Over Any Terrain vehicle, or G.O.A.T. Ford recently filed to trademark the acronym, which it’s using in its Bronco to select off-road modes using this rotary dial. There will be seven selectable modes offered including Normal, Eco, Sport, Slippery, and Sand for normal driving with Baja, Mud/Ruts, and Rock Crawl for off-road driving.
Pushing Buttons
2021 ford bronco
Just like the button in the Jeep Wrangler, the recirculation button on the Ford Bronco is simply an outline of itself. Is it corny if we say buttons like this are a nice touch? Yes.
Trail Sights
2021 ford bronco
Reminiscent of the first-generation Bronco’s tall pointy fenders, the new Ford Bronco incorporates the old look with what it calls Trail Sights. They’re tie-downs you can strap stuff to, for instance ORV flags, windshield cables, or even high-lift jacks. These tie-downs are limited to 150 pounds, so don't go using them as recovery points for getting pulled out of the mud. Unless you want to end up on YouTube.
More Broncos
2021 ford bronco
We've found a total of five broncos inside and out of the new Ford Bronco. This one is only available on Broncos with the ten-speed automatic transmission.
Push to Start
2021 ford bronco
This isn't so much a throwback to yesterday, as it is a reminder of today. The ignition button for the new Bronco looks familiar, because it looks just like one of the headlights on the front. Maybe just a reminder just how far cars have come from the days of two separate keys, each of which would either unlock or start the truck, never both.
1 - 1 of 1 Posts
