1 - 3 of 3 Posts
For sale:
Email [email protected]
All items are located in Laporte, IN. 46350 ( n/w Indiana )
Available for pickup or can be shipped at buyers expense.
1978 / 1979 bronco parts some will fit trucks with front radius arms also.
Dana 44 ford high pinion 4:88 gears limited slip disc brake axle disc to disc eight lug pattern. With calipers. Drivers side drop setup for radius arm front end. $500.00 o.b.o.
Dana 60 ford rear 4:88 gears limited slip drum brakes. Eight lug pattern. $500.00 obo
4 - 15” x 35 x 16.5 wide tsl boggers 50 to 60 percent tread, mildly grooved, no missing lugs. Mounted on eight lug Bart beadlocks 15” x 14 wide rims. Spare tire. Is a 15” x 35 x 14 wide tsl bogger, brand new tire, mounted on eight lug steel spoke rim. NO BEAD LOCK on this one …. These are all 15” rims the tires are wide ( 16.5” and 14 “ wide respectively.) $600.00 obo for all 5
ford 400 m c 6 trans with a 205 case (id go thru the trans and the mtr) the case is fine $200.00 obo
1979 ford bronco front and rear drive shafts lengthened to work with a 6 inch lift kit. $200.00 obo there is a dbl. Cardigan joint in the one… (shorten it to fit a jeep)
1979 ford bronco 6 lift front coil springs. $100.00 for the pai
Location (City):Laporte , Indiana
ZIP CODE (for shipping calculations):46350
Will you Ship? (Y/N):yes buyers expense
Method of shipment (UPS, FedEx, etc):whatevers easier/ cheaper...??
Payment method (PayPal, check, MO, etc):paypal, cash
Other info:
1 - 3 of 3 Posts
