1 - 12 of 12 Posts
I have a brand new redhead steering box on my 79 bronco. The other day I went and hauled a 65 chevy truck home on my trailer and noticed that at idle it did not want to steer. If I revved it up a little it steered like it should. Is this the pump going out?? It is not making any noise and is full of fluid. The only other thing I did was pull the truck out of its resting place and had it in 4x4 . The bronco spun in 4x4 a few times but cant see how this would have anything to do with the power steering pump going out. Always before I could turn my tires lock to lock idling on pavement.. If this is the pump has anyone rebuilt one before?
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual hubs
Well, not really sure, how old is your pump?
I installed a red head gearbox as well, bleed it a lot of times and its working good, not moving in idle can come from not enough fluid, not properly working pump as far as I can understand.
it may be possible that the gearbox fails, but then it would not work in higher rev's as well.
so its may be too less pressure at idle generated by pump.
My pump is leaking slightly, every time after starting engine, there is some oil drops on bottom of pump (lowest point).
Moderator and Scrounger Extraordinaire
Was it tougher to turn the wheel, or were the wheels not turning like they should? Too much rear end weight can make the front end light, and steering can really suffer.
65 Chevy huh? Stepside or traditional? 4x4? Is it a future project? I grew up with a black 64 c10 stepside (without spare tire cutout) rotting at the end of our driveway. Would've loved to 'pro-streeted' it, but it was just too far gone.
very good you solved it!!!
so steerings at all rev correctly!!
is there a peoject of your nice Bronco?
This looks pretty straight and good condition! Plus nice options, like pusher and sliding windows.
did you bring it back to this or it’s still nice off the days?
1 - 12 of 12 Posts
