1 - 13 of 13 Posts
My 1984 didn't come with the exterior tire carrier. I bought one form 1985 Bronco but I can't figure out where to holes should be drilled? I mounted inner tailgate support bracket, drilled holes for the tire carrier latch and mounted it. Hung the tire carrier on it to mark the cab corners and drill holes, but if I level the carrier with my tailgate body lines the bottom bracket sits to low, and it also hits the bumper? Is there a template for marking these holes somewhere?
Tire Hood Automotive tire Motor vehicle Grille
Automotive tire Hood Motor vehicle Bumper Tire
Car Vehicle Automotive lighting Motor vehicle Hood
Automotive tail & brake light Grille Automotive lighting Hood Automotive tire
Hood Motor vehicle Bicycle tire Automotive tire Wood
81 custom 351W Manual 4spd 83 XLT 302 manual 3spd OD
I would loosen the bolts on the bumper and see what you can gain. Looks like you don't need a whole lot clearing and you might be able to gain 1/16. You could also play with the brackets on the bumper, might gain a little there.
Another option - use a dremel tool and notch out the plastic.
Its not that simple... There is a structural bracket built into the body to support the wieght of the tire and rim that, if the Bronco didnt come with an exterior spare tire carrier, that support bracket is not in the truck, so you can't just mount it to the sheet metal, because it will buckle your quarter immediately.
Tire Wheel Car Vehicle Automotive tire
I have a bracket to put in the cab corner just need to bolt hole locations
Looking at his picture, measure the bolt hole recessed spot then use that as a reference to “measure” the photo to the body line for the top bracket use the actual measurement of your bolt hole as the size conversion measurement. I usually don’t make sense so if you don’t get it let me know.
edit : looks to be a little more then 2 bolt holes diameter down to that body line.
No problem,
Here are some pics I just took for ya from the bodylines, let me know if you need any more measurements.
1-1/8" Lwr Brkt hole to body line
White Automotive tire Hood Motor vehicle Automotive lighting
17-3/16 bottom upper hole, to top lower hole
Watch Automotive tire Motor vehicle Hood Bumper
1-3/8" from the rear view lwr brkt to the body line
Musical instrument Tool Wood String instrument Measuring instrument
2" from upper brkt bottom hole to the body line
Motor vehicle Tool Bumper Automotive exterior Wood
5/8" Lwr Brkt Rear view
Motor vehicle Automotive tire Hood Bumper Vehicle door
The Tennessee Warden
96 XL, built 357W, E4OD, BW1356, D44 SAS, 4.56 gears
No problem, I edited to include measurements in text because the pics skew a bit, but my measurements should get ya pretty close.
Thats the beauty of the bullnose sharp edges!
Wow that was a super helpful answer!
I thought it was near impossible to install the bracket if it wasn't there from the factory.
Did you have to cut it up and piece it into place?
you can put a plate of steel in there and make the bracing. theres a write up on here.
Yes am aware of the need for a support bracket either fabricated or factory. My bronco has the factory bracket & holes, & I just had my rear quarters off and had some pics I could share, so it sounds like everyone that has posted in this thread is aware of the need for this support bracket as well.
okie dokie
Reactions: Rob_64-365
1 - 13 of 13 Posts
