Group,
While in process of a bunch of stuff with my '80, I figured I would migrate to a 1991 M/C while I install the hydroboost (engine is a '91 so staying with that year for posterity's sake). Pros were the clear reservoir, elimination of that stupid wire bale cover retainer, and the ability to have a low level switch.
My new M/C didn't have this large fitting in the secondary (closer to firewall port), so I snagged one out of a yard. I now realize it is actually a proportioning valve. My '80 already has proportioning/metering/warning light valve from the factory.
Two questions:
1. Is the metering function (that delays fluid application to the fronts so the drums can energize) built into the 1991 master cylinder? My WSM makes no mention of such a feature but it is clearly called out in the 1980 WSM. Since I understand the brake systems to be similar minus RABS, I assume the functionality is still needed.
2. For anybody who's made this conversion, would it make sense to find a fitting that could adapt the M/C secondary port to the right size inverted flare? My 80's prop valve also acts as a distribution block, so removing that and trying to replumb looks less fun than the former, unless I just can't find a way to adapt the M/C to inverted flare.
Last but not least is just to stick the old M/C back on, but rather not if I can find a way around the current dilemma.
Thanks.
Two questions:
Thanks.
