yo,
Vacuum Line Routing Diagram in a 80 302, 351W & other engines
Source: by Chilton
Acronyms, Carbureted
acronyms (not nec. for your year/engine)
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACV: Air Control Valve
AIR: Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: AIR BPV is the AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CPRV: Canister Purge Valve
CBD: Closed Bowl Distributor
DIST: Distributor
DV-TW = Two Way Delay Valve
EGR: Exhaust Gas Recirculation
EFCA: Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
FLTR: Filter
FPR: Fuel Pressure Regulator
HEAT VLV INT = Heat Vacuum Control Valve Intake, (next to carb)
HICV = Hot Idle Control Valve
IVV: Thermactor Idle Vacuum Valve
LCV = EGR Load Control (WOT =Wide Open Throttle) Valve)
MAN VAC: Manifold vacuum-Vacuum source
MAP: Manifold Absolute Pressure
PURGE: Vapor Canister Purge Valve
PV: Ported Vacuum
PVS: Ported Vacuum Switch (PVS) Valve
PCV - Positive Crankcase Ventilation
SA-FV - Separator Assembly Fuel/Vacuum
SOLV: Thermactor Solenoid Valve
SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
TCP: Temperature Compensated Accelerator Pump
VAC: Vacuum
VCKV: Vacuum Check Valve
VRESER: Vacuum Reservoir Solenoid Valve
V REST on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time
VCV - Vacuum Control Valve
VRV: Vacuum Regulator Valve
V CK V: Vacuum Check Valve
VOTM - Vacuum Operated Throttle Modulator
VRDV: Distributor Retard Delay Valve
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
or
TVS: Temperature Vacuum Switch
TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches)
VRDV = Vacuum Delay Valve (VDV, VRDV, DV-TW)
VDV = Vacuum Delay Valve
yo, yw
Somehow I failed to add these two.
yo,
Yw
and esp. great!
