1 - 2 of 2 Posts
i have a 1981 bronco currently with the wrong transmission in it. Its a lot smaller then the one i have out side of the truck right now and a 3 spd not 4 and the truck has no reverse. I bought the truck like this with the right transmission out of the car a fly weel, and a clutch. any help on the best way to install all these parts or a point in the right direction would be helpful...if more details needed please ask
Does your trans have an aluminum case (the one in the truck now)? If its aluminum, its a RAT or a RAN. I'm assuming that if the one outside the truck is bigger, its cast iron with the shift lever on top. Does the new one(outside) have one side cover or 2? Is the lid cast iron or aluminum? It shouldn't be a huge issue to pull of a swap. You just need to do some comparison side by side. Lemme know.
1 - 2 of 2 Posts
