1 - 4 of 4 Posts
My search button skill may be lacking, please forgive me if I've missed something...
1984 Bronco XLT. I have some instrument panel issues to say the least. First and foremost is that none of the instrument illumination lights will come on. I had one spare bulb that I installed into the far left (near speedometer) just in case they all happened to be burned out. It's unlikely, but the cluster was in this condition when I bought the truck and it was cheap to check it. No go. I popped off the cluster power connector and checked the pins with a test light. Key on, headlights on. Bottom row 1-9 (left to right); numbers 1, 8, and 9 were hot. Top row (right to left) 10-18; number 13 is hot. Ran out of daylight.
Where do I go from here? Is there a relay or switch that I can trace back to and check voltage there? From what I have googled, the blue w/red on that connector = instrument lights. Light switch next?
Thanks for the reply! Yes, most gauges read correctly. I'll need to address the engine temp which is most likely a sensor issue. Turn signal indicators light up and flash correctly. Hi-beam indicator has a low-voltage constant on, but lights up brightly and correctly when I turn them on. 4x4+E-brake indicators don't light up, I'll pop a fresh bulb in those too. Speedo was good until I changed tire size and fuel gauge is spot on. I just can't see any of them when it's dark!
Like I mentioned above, there are some panel issues to say the least. I'm mostly concerned with getting the gauges illuminated as daylight is becoming more and more scarce.
Thanks for the wiring diagram! I noticed #5 on the connector was supposed to be hot from fuse #17 (5A). Mine had blown and was labeled instrument lighting. YES! Swapped that out with a fresh one but still didn't notice the instrument lights when I hit the headlights??? I have read that they can be very very dim, and the ceramic dimmer switch on the headlight switch can wear out and fail. That will be my next stop if I notice some dim illumination once it gets dark out.
edit: new bulbs, new fuse, replaced loose wire and the cluster is illuminated. Thanks for the help miesk5
1 - 4 of 4 Posts
