Next issue I had been dealing with for a while was my throttle bracket. It "worked" but it didn't work well. I don't know where I got the bracket itself, but it never lined up straight. Also, I had to make my own little bracket to hook the cruise control up with. The issue with the cruise cable is that it was designed for the 302 V8 that was originally in it, which has the throttle at the front of the engine. So the cable wasn't meant to reach over to where I have it. You can see in the bottom right of the picture that the sheath is starting to crack. This also made it pull from an odd angle.
The bracket also liked to wander, since it only had one little tab keeping it aligned. This would often make my throttle stick at around 3 - 5% when I let off the gas. I'd have to go and readjust everything and it'd be good for a bit.
Lastly, the cruise cable was just held on with a zip tie:
I started researching options to replace it. Unfortunately, since I have the 2bbl / 2300 style Sniper, options for aftermarket throttle bracket options are extremely limited. Most everything is for the 4bbl models.
On top of that, I simply can't believe how
difficult it is to hook up a cruise control cable to a carburetor! It's almost like no one's ever done it before, and I'm the first.
I researched for
weeks on just how to connect a second throttle cable to the carb and there was nothing. When I asked on several carb/Sniper forums, no one had any solid solutions. And those with cruise were using the stock setup that came with it.
I know that the majority of the crowd is racing and such, but cruise control is not exactly something new, so I was baffled.
Lokar had a custom connector to hook a cruise control cable to the main throttle, but it only came in a full on cruise control cable kit (that cost well over $100), and the parts weren't available separately.
So, I finally decided to just make my own. In the end, I'm super pleased with how it turned out, so I'm glad I did.
Oddly, when I was picking out steel, the thicker bar stock was less expensive than the thinner one, so it's getting a solid, beefy throttle bracket. 😁
First, I wanted the bracket to have two attachment points, since all my previous brackets have been single attachment, and they liked to wiggle and move. Then it needed to go around the Sniper unit. The spot where I'm putting it in the back has a bunch of wires coming out, so it needed some room.
A little bit of shaping, and then leaving room on the right to mount the bracketry for the cables:
Drilled and mounted the vertical bracket for the cable holes. Putting it together for some test fitting:
On the vertical piece, I marked where the throttle linkage connects and then drilled two holes. One for the main throttle and one for the cruise. The tiny hole in the bottom left is for the throttle return spring. Then, cut and shaped it a bit.
Flipped it over and cut and shaped more:
