I am having issues with my Bronco project. I replaced the carb, mechanical fuel pump, tank, tank vent valve, fuel sending unit and made sure the fuel lines were clear. When I attempt to fill the tank it struggles to get fuel into the tank and when you put the cap on it builds pressure in the tank to the point it will spew on you when you open the cap, within 15-20 minutes of just sitting there, not running.
That's one issue. The other is I cannot get fuel to the carb for some reason, so I assume the pressure issue in the tank is related. Can this be related to the SMOG system and that the AC and smog pump belt is not attached? I cannot figure out why the tank doesn't vent properly even with cleared lines and why I cannot get fuel to the carb.
Please help with any ideas or experiences. Thanks in advance.
Chris
Chris
