Disconnect exhaust and try again? I understand it is new, but factory made parts can be bad out of the box.
I'm pretty confident that it's not the timing.I've been thinking on this for a few minutes. Before you start swapping injectors, advance your timing to 16, just to see if it improves. I remember you saying something about different timing marks on your balancer, but regardless, if your headers are glowing, your too rich (fuel still burning on the way out) and/or timing is retarded. Since timing is so easy to adjust, I'd try that first. I'm assuming you didn't degree the cam using a different keyway on the timing set crank sprocket, right?
It kind of makes sense - if your spark is too late, it'll ignite the fuel as it's exiting through the exhaust valve and you won't be able to rev it. I know that it WAS running fine before, but I figure,,,it's easy to check and you can always move it back if it doesn't improve anything.
I dunno man - you have a wet spark plug, you smell fuel, and your headers are glowing…I’m saying it’s rich or you have a couple of bad injectors dumping fuel. As far as the timing, I figure it won’t hurt to advance it more just to see if it helps.I'm pretty confident that it's not the timing.
Judging by the plugs, it's not running rich, all plugs look the same. Cylinder 4 was wet. Assuming that was last cylinder to not fire before I pulled the plugs.
The injectors I used I got from someone on here as a trade about 18 months ago. They were used but were EV6 style. Don't know the history of them.
I'm really thinking that it's a fuel delivery (lean) issue as of now. Could it be a computer connection? Maybe as the latest development came about after I unplugged the computer for a photo shoot of the code, AND hooking up the front oxygen sensors. However, as I stated it's been a gradual decline from first fire up. Maybe I'll pull the computer too and have a look inside. It did come from a parts Bronco.
Remember this is sequential fire and not batch fire for the injectors therfore there should be one wet plug . The compression check was done without the key in and turned. I jumped the relay to crank it.I dunno man - you have a wet spark plug, you smell fuel, and your headers are glowing…I’m saying it’s rich or you have a couple of bad injectors dumping fuel. As far as the timing, I figure it won’t hurt to advance it more just to see if it helps.
Lean condition could make the headers glow too with more oxygen going through them, but not being able to rev the engine, combined with the wet plug and smell of fuel, makes me think rich.
Have you tried unplugging the O2 sensors?
