I took it to one shop and they quoted me 800 bucks to fix it. They pulled the codes and told me it that the abs dump valve needs to be replaced. I have searched up in down in Haynes, and online and can not find anything called a dump valve.... anyone have any ideas???
Had the same problem on mine. If you follow the brake lines from the MC down to the driver's side frame rail, you'll see it. I ended up just putting a union in place of it and removing it.
So it just the hydralic valve for the abs, not anything else. I figured that is what it was, but I have never heard it called a dump valve before.
Lick my balls
How can they justify charging that much?
They said it would take a whole day to do it.... then they tried to charge my an 80 dollar diag. fee which I hadn't agreed to. If it is just tht vavle I should be able to do it myself.
