1987 EFI Starting Problems.. Partially Fixed!! code 34?
ok so it starts fine the first time..(after it sits for a while) then try to crank it up again and 80% of the time it just cranks.. i then have to hold the gas peddle to the floor, crank and it sputters up to an idle.. then runs fine until you try to start again.. ive taken it to a mechanic twice..
1st time he replaced the Ignition Module and Pickup $295.41 :banghead
2nd time he replace the In tank Fuel Pump and strainer $326.42 :banghead
so ive been religously searching and reading these forums for similar problems.. i think it may be the Fuel Pressure Regulator..
could this be? and should i test the line if it runs perfectly fine?
any help would be greatful :thumbup
its a 5.0 btw
its a 5.0 btw
