1 - 2 of 2 Posts
I recently removed my rear seat for an off road trip so I could sleep in the back of my bronco. When I removed my seat I broke off the rubber stopper on the back of the rear seat and I can’t seem to find a replacement. I have a 1988 Bronco XLT with a 5.8 351w.
Yo Doc,
Stop by local Ford dealer parts department using this, if this what you need;
Rear, Floor Latch pic in an 88
166664
Source: by Jem270
Or, this;
166663
ItemPart NumberDescription
155929-S2Screw (2 Req'd)
298605B28Plate, Rear Seat Cushion Scuff (1 Req'd) (LH Side Only)
3613A38Rear Seat Back Frame
4387871-S2Bolt (4 Req'd)
5383493-S2Washer
667412Latch Assembly — Rear Seat Cushion
7604K22Rear Seat Cushion Torsion Bar
8N804266-S2Screw (4 Req'd) (RH Side)
9385329-S2Bolt
1060514Rear Seat Back Pivot Bracket (1 Req'd) (LH Side Only)
11387871-S2Bolt
12383493-S2Washer
13111B42Rear Floor Pan Opening Cover Plate
1462440Rear Seat Back Latch Striker
15387871-S2Bolt
16378444-SPlug
1767438Check Spring
1867440Check Spring Retainer
1963160Rear Seat Cushion Frame
20382552-S100Washer
ATighten to 54-81 Nm
(40-60 Lb-Ft)
BTighten to 16-24 Nm
(12-18 Lb-Ft)
CTighten to 18-27 Nm
(13-20 Lb-Ft)
1 - 2 of 2 Posts
