1 - 3 of 3 Posts
1988 Ford Bronco V8 Four Wheel Drive Automatic 185000 miles
when im driving down the road about 15 mins after i fire it up the trucks oil pressure drops really low and the engine light comes on and it starts to spit and sputter i just replaced the following: spark plugs and wires,fuel regulator, distributor module, fuel relay, fuel filter,distributor cap,rotor button, alternator. i ran fuel injector cleaner threw it.
the fuel rail pressure rail was at 13.5-29 psi and it fluctuated and stalled then cut off
what could the problem be please help
mulitple problems...
you more than likely have crap in your oil pan that is getting caught on the pickup screen, you'll have to drop the pan for that one i'm afraid. It's not terrible, but not as easy as it should be either.
sounds like you have a bad fuel pump or at least a clogged up pickup filter in your tank.
The low pressure on the fuel rail says it all.
of course that's my opinion, I'm sure some more folks will be along shortly to give you advice.
hey thanks man im gonna drop the oil pan tomorrw then and if that anit if then im replacing the gas pump i might replace both of them cause i have 2 pumps
1 - 3 of 3 Posts
